HP Racing Header 4-1 w/high flow cat.
What a pain to install... The stupid thing won't clear the solid part of the engine mount.
I have my car on jack stands waiting for this thing to go in. I refuse to put the wheenie tiny stock header back on. I guess I'll have to try again tonight. I guess after a few hours you get frustrated. That and HP has been dissapointing. It didn't come with a plug for the extra sensor ( I have an EX), and mine didn't come with any O2 simulators, on instructions (bought it from NOPI...is that the reason? Should it come with those? I haven't even got to putting it on yet...hopefully I won't run it to any more problems. If anybody has any advice on the install, it would be appreciated. There was an old thread on this, has anybody else had these problems lately?
MiHo--------
Installing this weekend:
Tokico blues
CAI
Neuspeed strut bar
Magnaflow w/ custom 2.25" piping
NGK Irridium 9's
Mobil 1 Synthetic oil w/K&N Oil Filter
My ride---2002 Black Civic EX w/ 17" G-racing suki wheels/slotted,drilled rotors w/ceramic pads/Jaguar style tail lights/Evotion springs/SPC Camber kit.
I have my car on jack stands waiting for this thing to go in. I refuse to put the wheenie tiny stock header back on. I guess I'll have to try again tonight. I guess after a few hours you get frustrated. That and HP has been dissapointing. It didn't come with a plug for the extra sensor ( I have an EX), and mine didn't come with any O2 simulators, on instructions (bought it from NOPI...is that the reason? Should it come with those? I haven't even got to putting it on yet...hopefully I won't run it to any more problems. If anybody has any advice on the install, it would be appreciated. There was an old thread on this, has anybody else had these problems lately?MiHo--------
Tokico blues
CAI
Neuspeed strut bar
NGK Irridium 9's
remove the front mount. Put a jack under the engine and push it up a bit to get the clearence you need to get the header in. It is tight. You are going in from under the car right? .
MiHo
Originally Posted by miho
Yeah, I'm going in from the bottom. Actually, let me call my friend up, his at my house trying to finish up right now (Now thats a good friend). So all he has to do is remove the bolt on that motor mount and jack it up? It won't damage anything?
MiHo
MiHo
remove the big bolt and then the 3 smaller ones holding the mount to the tranny. The stock mounts will allow the engine and trans to flex and move a bit with some pressure from the jack. This should help alot.
Thanks for the info. I just called my friend and that's exactly what he is going to do. Hopefully that does it. I'm just anxious to get the rest of the mods done this weekend.
mIhO
Header is in!!!!!!!!!!!!!!
Header fit after removing the engine mount. Only problem now is the nuts for the spring bolts are welded on the OEM header. Now I have to stop by the store and pick up some nuts so I can finish the install. I'm wondering if these bolts are supposed to come with the kit? Has anybody else had this problem. Hopefully it wont leak after this.
mIhO
mIhO
Hopefully it wont leak after this. [/COLOR]
mIhO
mIhO
......I installed mine about 2 months ago I its been Great...... Joined: Jun 2002
Originally Posted by DJ_NILOCIVIC03
the Nut for them its made into the header.......you don't need other nuts....
you might be thinking of the bolts that go from the original cat to your exhaust. for that you'll have to pick up some hardware.
first drive
Finished with the install...whew!! It doesen't leak (thank you everyone for their comments and help). Now I have to fix that damn rattle from where it hits the pipe. I was going to use my dremmel, but I figure I'll wait till Friday and use my friends blow torch like I've heard others say. Hopefully that works best. Other than that, you feel the gains right away, Now I'm putting in the CAI. Hopefully this goes a little smoother. Again, thanks for the tips.
mIhO
mIhO
I used a Angle grinder...I finished like in 10 minutes and it was smooth......
Don't use a torch......you'll make the frame weak using heat.....I can't think of the word for that
but the metal won't be as hard as it was....
mIhO
Thanks for the idea. I'll just have to find someone to borrow it from. Thanks again.
mIhO
mIhO
I work for Pepsi, and go figure, the fleet department has everything I need. 27mm sockets...grinders and chestfuls (organized) of metric bolts and nuts...heaven I tell you... So I'll be grinding tonight...too bad I have to take out the header and disconected from the cat, thats going to suck
..but tomorrow morning my magnaflow
gets intalled along with my tokico blues...CAI should be finished tonight (recomendation: NOPI makes a good CAI, exactly like the AEM, just have to figure out how to make the IAT sensor stretch to the hole...next challange). I'll hopefully have pics soon...next up...50shot of nitrous.
mIho
gets intalled along with my tokico blues...CAI should be finished tonight (recomendation: NOPI makes a good CAI, exactly like the AEM, just have to figure out how to make the IAT sensor stretch to the hole...next challange). I'll hopefully have pics soon...next up...50shot of nitrous.mIho
[B]... So I'll be grinding tonight...too bad I have to take out the header and disconected from the cat, thats going to suck
mIho
..mIho
Installed
Go figure... I like the ride... the car is quite a bit quicker...but I hope it would be after spending that much money...I hear that I should give it a couple of weeks to see how everything settles. Now I have to buy the 02 sims to make the check engine light come off. The tokicos make a big difference. I will post pictures soon.
Anybody recommend a certain type of 02 sim? what works best for our cars? Thanks,
mIhO
mIhO
HP are the dumbest people in the business. Seriously, they sent me two o2 sims and instructions for a Lexus IS300. I thought maybe it was the same process as the IS300 but i was soo wrong. Even when i called HP and spoke to Damian he said to take it to a professional. I responded with a simple logical question, "why, if I purchased the correct model number for my civic ex 02, did you send me the wrong instructions and tell me that I'm installing it wrong? Told me he didn't know.
They have a decent product but they are simply retarded. damn it that makes me mad. i wasted so much time trying to figure the wiring out. Plus, the friggin header hits against the subframe! SOBs! Its like they have cheech and chong working the shipping dept over there. and why can't they make the header fit properly?!
ok, i'm done venting.
Originally Posted by kornsined
casper o2 sims is exspensive but is fool proof easy to install. just plug and play and no splicing or anything.
mIhO
mIhO
Touge
Sep 23, 2015 10:51 PM
Touge
Ottawa
Sep 22, 2015 11:58 PM
Touge
Sep 1, 2015 11:25 PM
