Question for Exedy organic clutch with stock flywheel users
Old Mar 3, 2005
Alex1's Avatar
I bought an Exedy organic clutch kit. I read somewhere that you had to use the 212mm 1.6 SOHC flywheel to use this clutch kit. Is this true? Have any of you installed and use this clutch with just a stock resurfaced flywheel?
Old Mar 4, 2005
2K1Civic17"Gabe's Avatar
PM Street Level Performance, they are selling those right now, and he told me not to get a lightened flywheel with that clutch (but for boost purposes). It is good N/A or maybe nitrous. It is not needed though, unless you bought the wrong thing?
Old Mar 4, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
The organic clutch is designed as a stock replacement clutch. You should be fine with the stock flywheel assembly.
Old Mar 4, 2005
Alex1's Avatar
Thanks guys, I just wanted to make sure before it gets installed.
ghondavic
Transmission
Apr 12, 2017 09:37 PM
bsmiley
Apr 27, 2015 01:27 PM
