AEM SRI dyno
Old Jan 21, 2005
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
AEM SRI dyno
Why doesn't AEM have a dyno chart for the SRI for a 01+ manual trans?
Old Jan 21, 2005
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
not worth the dyno...
Old Jan 21, 2005
Mirage's Avatar
Mirage is an unknown quantity at this point
According to the Dyno posted for the 01+ EX A/T, the SRI gave a best gain of 6.6 HP @ 5,750 RPM. Since the engine & the SRI P/N is the same as the M/T I would expect similar gains.
http://www.aempower.com/pdf/dyno/22-...20AT%20SRS.pdf
Old Jan 21, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I wouldn't trust AEM's website too much ... they said the aem v2 gave a 16 hp gain on the 01+ dx :|
Old Jan 21, 2005
bobsagator's Avatar
I understand the idea of "similar gains" but since the torque curve of a A/T is different from a M/T then it really wouldn't be a true comparison, would it?
Old Jan 21, 2005
orion_squall's Avatar
it is not bad...
I didn't know it gives more than 1hp
Old Jan 21, 2005
hotrodcivic2004's Avatar
my civic has no boost
the 6 horsepower isnt even at 6100 rpm where the civic ex peaks at stock....i think it was around 4550 was +6 horsepower and at 6100 was like 3 horse. i never heard about that +16 horsepower that seems kind of high, but i wont argue wiht a dyno chart.
Old Jan 21, 2005
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
it wasn't a dyno chart... it was an excell graph
Old Jan 22, 2005
scatman's Avatar
Still in the game...
i concur.
Old Jan 22, 2005
They don't show a dyno if it gives less hp than stock. It's bad for business.
Old Jan 22, 2005
xX03EXx's Avatar
Sweetest Dude on 7th Gen
Yeah, i switched my aem cai back to stock airbox and the gains are ridic. CAI slowed down the car.
Old Jan 22, 2005
jackal903's Avatar
jackal903 is an unknown quantity at this point
stock air box = best for D17
Old Jan 22, 2005
se7engen_riDe's Avatar
se7engen_riDe is an unknown quantity at this point
are you sure that chart is right? 6.6 hp gain just with a aem SRI is kinda high dont you think? if that chart is telling the trueth then it does more then i thought it would do.
Old Jan 22, 2005
diskreet's Avatar
Thats like a 100% gain. Man the D17 sucks at everything but fuel economy.
Old Jan 22, 2005
jakejham's Avatar
jakejham should not be trustedjakejham should not be trusted
^^ true. maybe ill go back to my stock airbox and choke it even more with one of those "ToRnAdO" air swirlies. then the d17 will show it's true potential......
45mpg!!!
Old Jan 22, 2005
Mirage's Avatar
The torque curve of the ENGINE is different?
Old Jan 22, 2005
Mirage's Avatar
evidence?
Old Jan 22, 2005
evidence?
-piping the same size as the TB = best = stock
-resonator matches air charge with intake pulses
-stock airbox acts as a reservoir of air ensuring power on demand
(more torque)
-stock intake is designed to keep air moving fast
An aftermarket intake usually only meets one of these requirements, if any.
If the oem intake was flawed or in some way restrictive, you would be seeing alot more than 4whp gain at 6200rpm after swapping to an aftermarket K&N intake.
Old Jan 22, 2005
Mirage's Avatar
False
False, the resonator is for sound reduction
-stock airbox acts as a reservoir of air ensuring power on demand (more torque)
Could not be more False
True, but irrelevent in this case. btw, so does a straw
I didnt see any valid requirements above so I can't comment.
False. Removing one restriction does not remove all restrictions. But if what you are saying is true, then how did you get +4 HP with the K&N?
Old Jan 22, 2005
Oh well I tried. To me anyway, the stock intake feels faster because I drive more in the lower rpms. I really couldn't tell any gains with the K&N to justify keeping it. Maybe look up the definition of resonator. It's more than just sound reduction.
Old Jan 22, 2005
Mirage's Avatar
I am quite aware of what a resonator is and they can be more than just sound deadener but unfortunately that is all it is used for in the case of the factory D17 intake. Thats not true for all intakes though, the whole concept of the AEM V2 intake is to tune the inlet tract resonation to give a more pronounced charge air effect.
Also, You have to be very careful about how a car feels after a change. The majority of people cant feel a 5 hp difference. I have dynoed & tuned many, many cars and I cant feel 5HP, I assume others can't as well. That is why I always want a true before & after dyno test before I judge if something is any good.
Old Jan 22, 2005
Yes which is why I'll be getting one more dyno done before I say anything about pullies and header. I hate to just guess at it. I can feel a difference with the intakes tho, not much but it's there. But on a D17, 5-10whp is alot if it's only starting with around 80.
Old Jan 22, 2005
Wolfgang5884's Avatar
so true
Old Jan 22, 2005
skipbarber's Avatar
i dunno, i have to agree with gearbox.. the resonator is acoustically designed...which deals heavily with how the air travels. Nothing will give you the same filtration as oem either.
Old Jan 22, 2005
You know, some service guy at the dealer was talking with me, and when I told him I put the stock back in, he seemed to know alot about why it's so much better. Seemed kinda odd because he was all into performance. He said on these cars tho, stock makes more power. I believe it.
Old Jan 22, 2005
so if stock makes more power why the hell are all of us sticking aftermarket intakes in our car just to reduce power. i dont understand how a bunch of heavy, black boxes with a tiny intlet tube is better then a wide, short aluminum tube with a big cone filter on the end that allows fast flow...
Old Jan 22, 2005
Beats me. I just know my car feels its fastest and best right now out of the three years I've had it. And that's with stock intake (I've tried K&N and AEM) and stock exhaust.
Old Jan 22, 2005
Mirage's Avatar
Rather that what feels fastest, what were your horsepower values with each of the above listed mods? What were your 1/4 times? If you dont have at least that, how can you claim to make any kind of an informed decision?
Old Jan 22, 2005
Mirage's Avatar
Originally Posted by Wolfgang5884
so true
sorry, but so false.
Do you actually think that something that was dynoed with a +HP gain on an A/T would lose HP on a M/T?
If so, why?
Old Jan 22, 2005
I gained 2whp after tuning the a/f with stock intake
