Cca & H2o
Old Jan 10, 2005
2k Si MSTR's Avatar
2k Si MSTR is an unknown quantity at this point
Cca & H2o
i am considering upgrading to CCA, but i need a little info that i can't seem to find anywhere else... i have 2k SI, and my main concern is water. i've read that CCA can suck water into the intake tract and i don't want that... is there any totally effective countermeasure in preventing water from being sucked in? or does this only happen under extreme circumstancies? (i.e. completely submerged)
also: i've been mainly focusing my attention on K&N CCA (typhoon) , is there any other more effective alternative?
Old Jan 10, 2005
wonderz's Avatar
wonderz is on a distinguished road
what's cca? do u mean cai?
Old Jan 10, 2005
2k Si MSTR's Avatar
CCA; Complete Cold Air
Old Jan 10, 2005
diskreet's Avatar
With AEM you can buy one of their "bypass valves". yes water can get sucked in if its submerged alot. this valve is just a foam filter that fits into the CAI tube somewhere. if the filter fails (submerged) then it sucks from the 'valve' not the normal filter.
AEM’s patented air bypass valve virtually eliminates the chance of hydro-lock in the event the filter of your AEM Cold Air induction system becomes submerged in water. The valve installs along the upper portion of the inlet pipe and shuts down induction at the filter when it becomes submerged, rerouting air through its external diaphragm to keep water out and air flowing in. Patent # 6,394,12
http://www.aempower.com/product_intake.asp
Skunkone
Sep 24, 2015 04:38 PM
smmahan
Apr 15, 2015 08:17 PM
Berto
Jan 19, 2011 06:41 PM
gearbox
7th Gen Do It Yourself Articles
May 1, 2008 10:57 PM
gearbox
Jan 31, 2005 02:29 AM
