how long it takes to install this?
Old Dec 6, 2004
se7engen_riDe's Avatar
se7engen_riDe is an unknown quantity at this point
I finally got my megan racing down pipe in today. All I need to know now is how much it costs and how long it takes to install this thing onto my car. Anybody know?
Old Dec 6, 2004
bgoetz's Avatar
bgoetz is an unknown quantity at this point
does it bolt on?? or do you weld it???? If it bolts on it is only a matter of unbolting 4 bolts and bolting the new one up. If you have to weld it you should take it to someone, unless you can weld, in which case I doubt you would be asking this
Old Dec 6, 2004
Bmkarr's Avatar
Bmkarr is an unknown quantity at this point
if you know what your doin it wont take that long first unbolt the o2 sensor from the cat (you'll have to take the heat shield off) then all you have to do is unbolt the cat from the header with the two tension bolts, then the three bolts that connect the cat to the resonator. then your cat will be hanging by the lil black ******** just take that off and your cat will drop then do the steps in reverse with the downpipe.
i did mine in about an hour, but i have HP Racing 4-2-1 headers to HP Racing Cat so its alil diff. but the steps should be the same.
Old Dec 6, 2004
an hour just to install a down pipe? hmm...
Old Dec 6, 2004
NashVegasEX's Avatar
NashVegasEX is an unknown quantity at this point
if you have a lift available it takes 10 minutes, but yeah, with no lift, hand tools, and a couple rusty bolts mine took 45 minutes to an hour ... Of course, I had to stop to smoke a couple times ...
Old Dec 7, 2004
realitycheck's Avatar
realitycheck is an unknown quantity at this point
Yeah, you also need a nice little o2 sensor tool from auto zone, I finally got mine off without it. It is a royal pain though to try and do it without the tool, if I had gotten the tool when I did mine I could have done it alot faster. Also if you dont have a mil eliminator your cel will come on.
Old Dec 7, 2004
wrussi's Avatar
wrussi is an unknown quantity at this point
i installed my exhaust like in 30 minutes
!. lift the car with towers if u have some or some really good jackstands dont use the factory one is dangerous
2.spray a lot of wd40 or something like that b/c those bolts are really tight
3.unbolt them both midpipe and rear section
4. mount and adjust the new one make sure nothing is touching
5. mount rear section make sure everything is adjusted
6. clean up
7. lower the car
8. smile
9. drive
Old Dec 7, 2004
R3DL1N3's Avatar
im taking my megan downpipe off. its really loud.
Old Dec 7, 2004
loud? how loud?
Old Dec 7, 2004
Depends on what kind of muffler you have, I have a tanabe catback with mine and its loud but not too loud. At least not for me, I love loud.
Old Dec 8, 2004
exturbo6's Avatar
well i had a megan racing downpipe, and then i took it off for my turbo. and thank god for the turbo kit, cause the freakin downpipe made my car sound so raspy. and loud, ****, if you could hear yourself think in the car it would have been nuts..but i guess thats what happens when you dont have a cat or a res. to a apexi n1 muffler. but now after the turbo kit. dam it sounds so nice. now it sounds like it should. all motor too loud for me. turbo is very nice.
jackoncruzpr
May 24, 2015 12:24 AM
jackoncruzpr
Apr 16, 2015 12:29 PM
StLVtec
Nov 14, 2001 09:22 PM
SneakerPimp
Nov 5, 2001 10:49 PM
