Auto to Manual Conversion
Old Oct 24, 2004
civictuner's Avatar
civictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trusted
What parts is need for a manual conversion??
Manual Trans(incl. Clutch, Flywheel, Throw out bearing)
Pedals
Resevoir & lines and cables
ECU
shifter linkage and the whole shifter console
ANYTHING ELSE??????????????
Old Oct 24, 2004
dalaw's Avatar
Bone Stock!
just buy a new car
Old Oct 24, 2004
jmiester96's Avatar
jmiester96 will become famous soon enoughjmiester96 will become famous soon enough
thas a lot of money and work for nothin, if it was a fast *** car it would be diff, but its a civic, we're all slow.
Old Oct 24, 2004
bgoetz's Avatar
bgoetz is an unknown quantity at this point
these are the parts anyone you says different does not know ****
1.)everything listed above -ECU (PM me to find out how to make your ECU work)
2.)master/slave cyl.
3.)clutch/ flywheel
4.)shifer cables (buy new)
5.)axles(yep they are different)
6.)tranny side mount, and front engine mount
7.)new subframe, our have someone move the front mount bracket 1 1/8 inch to the right if you are facing the car
8.) manual tranny starter
9.) misc. nuts and bolts
10.) new guage cluster or paint old one
11.) A LOT OF BEER
*** I would also recomend a helms manual (not just recomend it is the most important thing you could buy) and alot of borrowed tools from autozone
If you have any questions PM me
Old Oct 24, 2004
Mr.Modify's Avatar
Search Buddy...
http://www.7thgencivic.com/forums/sh...d.php?t=123114
Old Oct 24, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
Originally Posted by Mr.Modify
Old Sep 7, 2005
ImportRacer2123's Avatar
K20 Member
I have the Shifter Cables for sale for the Manual Swap.
Old Sep 7, 2005
Boggie1688's Avatar
Diamond Member
Boggie1688 is an unknown quantity at this point
Good Luck with that...sounds hard...why didn't u just get a manual in the first place??
Old Sep 7, 2005
K20 Member
its really not hard at all... i am finishing up a auto to manual conversion along with a k20 swap.
Old Sep 7, 2005
02cvcEX's Avatar
02cvcEX will become famous soon enough02cvcEX will become famous soon enough
i wanted to do a manual conversion b/c my a/t is slipping BAD, but when i compared the cost of replacing the a/t and converting to manual .... a new a/t would be alot cheaper and less work =)
good luck on the conversion ... search on the forums for help
o yea.. my parents bought my car so i had no choice but to choose auto.
Old Sep 7, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
almost a year old.
Old Sep 7, 2005
Boggie1688's Avatar
Diamond Member
omg...idiot i am...hahaah
Broadbeb
May 14, 2015 09:49 PM
oneheadlight
Apr 29, 2015 11:30 PM
davidpaustin
Apr 29, 2015 02:23 PM
C6GrandSport
Apr 25, 2015 09:41 PM
SugarRay
Jan 7, 2002 08:20 AM
