Revo SS install
Old Oct 7, 2004
varmin's Avatar
just a troll who likes to laugh at YOU.
varmin will become famous soon enough
Revo SS install
hey.
i'm getting my revo SS kit tomorrow, but the stuff from gray and capyoda probably won't be here til next week. i wanna put the SS on this weekend, but don't want to go through hell taking it back apart to throw in gray&capyoda's kits. so i guess i want to ask y'all revo owners, how bad will it be to open it back up and put in the bushings, etc. later? should i just wait til i have all the parts? it doesn't look like a hard install, but i don't even know what the other kits will take in terms of work.
Old Oct 7, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Not hard at all. Once you have the shifter console off, the shifter assembly is just 4 bolts and two clipped cables with cotter pins anyway.
Old Oct 7, 2004
IDQcivic's Avatar
IDQcivic should not be trusted
make sure you don't overtighten those bolts because the nut is welded under the car, and if you get it to tight that nut will come loose and it will be a paint to get off.... I would just wait until you have everything to do the install...
Old Oct 7, 2004
snowboreddave's Avatar
snowboreddave is an unknown quantity at this point
patience is a virtue.. just wait till you get all your stuff man..
Old Oct 7, 2004
FALKEN's Avatar
Civicforums Junkie
just wait until you have everything, then you only have to mess with it once
Old Oct 7, 2004
exclusive_vtec's Avatar
Old Oct 7, 2004
centurioncivic's Avatar
centurioncivic is an unknown quantity at this point
hah, why does eveyone waste money on the greys and capa yoda kits anyways.I have the revo ss and my frined has the revo ss with greys and capa yoda kits and i can tell ABSOLUTLY no difference. Even in really hard shifts
Old Oct 7, 2004
IDQcivic's Avatar
the bushings make a difference over the rubber stock ones, so thats a good investment, but as far as tightening up the linkage, you can just buy a few washers at any hardware store to put on before the cotter pins....
Old Oct 7, 2004
modoman's Avatar
yea just wait, its easy install but its a pain in the ***
Old Oct 7, 2004
varmin's Avatar
ok, i'll wait. maybe. i have no patience.
thanks for the input.
Old Oct 7, 2004
IDQcivic's Avatar
Hey while we're waiting.... does anyone know of any shift ***** that fit the revo that actually SCREW on? I am sick of that crappy shift ***** with the plastic inserts and the allan set screws!!!
Old Oct 7, 2004
modoman's Avatar
the rsx aluminum **** fits perfect and looks goooood, you just have to use the boot adapter to make the **** look like its meant to be on there... if that makes sense...
i think i have a pic of mine ill post if i find it
ahhh here it is... if you look, that plastic ring around the boot holds it up so it doesnt look retarded.
Old Oct 8, 2004
gtracing's Avatar
TeLLy is my daddy
gtracing is an unknown quantity at this point
^ that's why you should go with b&m!!!! haha, the b&m shaft is much thicker than the stock and the revo one....the shiftboot can only go down till the end of the threads then i'll be caught there and can't go any further down....mine sits flush against the **** and i love it!!
Old Oct 8, 2004
varmin's Avatar
how much does the boot adapter cost at the dealer?
/too lazy to search
Old Oct 8, 2004
FALKEN's Avatar
Civicforums Junkie
part number: 08999-BAK-100
my cost: $5.25
Old Oct 8, 2004
runner1738's Avatar
i have the revo ss , and just wondering does anyone else have trouble putting it in reverse sometimes?
Old Oct 8, 2004
modoman's Avatar
i have to kinda slam it in there sometimes, or pull it out and try again
Old Oct 8, 2004
FALKEN's Avatar
Civicforums Junkie
i do the same to my wife
Old Oct 8, 2004
varmin's Avatar
i have a little trouble getting into reverse w/ stock...but i had my trans re-worked once already. i hope it don't get worse when i put on the revo.
Old Oct 8, 2004
modoman's Avatar
AHAHAHHAHAHAHHAAHAH
Old Oct 8, 2004
varmin's Avatar
i gave in to impatience and put the Revo in (just now!).
wow.
i can see it will take a little while to get used to, but the throw difference is great.
i can also see why gray makes that kit, the retaining clip does rattle. it won't take much to pull it out and put those in next week though, and i get to drive it now...:P
Old Oct 8, 2004
CapYoda's Avatar
Escaped Convict
lol yeah damn that stock retaining clip. its meant to be used only once or something.
I'm not sure which one is ur order, but I shipped them all out already (except for one thats still pending clear payment)
so u should get it soon.
Old Oct 9, 2004
tanabe79's Avatar
tanabe79 is an unknown quantity at this point
wow.
Dude! i just ordered my Revo SS and cant wait to get it does it really rattle bad w/o the bushing kit i guest i have to get that to.
Old Oct 9, 2004
modoman's Avatar
my cotter pin rattle went away mysteriously after a few weeks so eh
Old Oct 9, 2004
gtracing's Avatar
TeLLy is my daddy
^did u use a new cotter pin or used the old one? and about the reverse thing, i think everyone has trouble with it...cause i remember i had trouble with it before i got my b&m...and same with first gear, sometimes i have trouble getting into first
Old Oct 9, 2004
someguy's Avatar
someguy is an unknown quantity at this point
if you let out the clutch just a little bit when your trying to put it in reverse...it should slide right into gear. happens to me a lot...my friends and i figured that if you do that it goes right into gear.
Old Oct 9, 2004
modoman's Avatar
i used the old cotter pin i believe, i dont think the revo came with new ones.
also if you double declutch and blip the gas you can get it into first a whole lot easier, just match revs cuz i used to have the same thing happen
Old Oct 9, 2004
CapYoda's Avatar
Escaped Convict
er no it doesnt rattle bad.
Old Oct 11, 2004
varmin's Avatar
for me the rattling part is the clip that holds in the main cable. it rattles if you shift hard, like a little 'jangle' kinda sound, not very loud but...it's annoying enough that i want it to stop, that's for sure.
Old Oct 11, 2004
silverem2's Avatar
how much the capyoda's part cdn shipped to canada?
