Best ECU Mod?
Old Sep 23, 2004
ofourcivic's Avatar
ofourcivic is an unknown quantity at this point
Best ECU Mod?
I have an automatic 2004 Civic EX and have been trying to decide on what fuel/air management system to go with:
- AEM EMS
- Greddy E-Manage
-Apexi VAFC-II
-Venom 400
What do you guys reccommend, and will all of these work with an automatic transmission. I plan on getting turbo within a couple of months, if that makes any difference.
Thanks!
Old Sep 23, 2004
VTECTypeR's Avatar
Well if your going to get a turbo get the greddy emanage.
Old Sep 23, 2004
djmota's Avatar
- AEM EMS not applicable to the 7th gen
- Greddy E-Manage definatly the way to go, Especially with a boost application.
-Apexi VAFC-II not that great
-Venom 400 this will advance your timing a bit.. bad for boost
Old Sep 23, 2004
someguy's Avatar
someguy is an unknown quantity at this point
why does AEM say that their ecu is for our gen? has anyone bought it? do you know for sure? cause i was looking to getting the AEM EMS. also i heard the greddy ones werent that great, but thats what i heard. just wondering.
Old Sep 23, 2004
Not available yet. The venom only tricks some sensors, and the vafcII gets reset by the ecu. So get the e-manage and the bypass that sends the ecu a fake "okay" signal under 1psi of boost.
Old Sep 23, 2004
Silversleeper's Avatar
Silversleeper is an unknown quantity at this point
What exactly does it do to a N/A car?
Old Sep 23, 2004
djmota's Avatar
adjust fuel curves. Also with the ignition harness, it allows your to advance or retard your timing.
Old Sep 23, 2004
ofourcivic's Avatar
is the Greddy E-Manage compatible with an automatic transmission, I had heard it wasn't.
Old Sep 23, 2004
snowboreddave's Avatar
snowboreddave is an unknown quantity at this point
there is no point in getting an EMS unless you have some serious mods (i.e forced induction or severe engine work).. save your money and do your mods first.
Old Sep 23, 2004
sasquatch's Avatar
sasquatch is an unknown quantity at this point
Emanage and Auto...
I have no experience with the unit but that is what Dezod is using in his kit right?
Old Sep 23, 2004
VietScouty's Avatar
VietScouty is an unknown quantity at this point
Hmmm...I'm not sure about tha turbo application...isn't that only for manual?
Old Sep 29, 2004
IronFist's Avatar
VAFC II gets reset by the ECU? wtf?
Old Sep 29, 2004
Ledbelly's Avatar
Im the man in the box
unless you have some engine work done it would be kinda pointless to get any type of ems. put in some mods first
Old Sep 29, 2004
jdm_bb's Avatar
jdm_bb is an unknown quantity at this point
What would be the best for N/A if i have an LX?
Old Sep 29, 2004
civiclx4dr's Avatar
civiclx4dr has a little shameless behaviour in the past
whats the best piggyback mod for a lx with I/H/E? IMPROVING THE QUARTER MILE TIME?
Old Sep 29, 2004
vafcII is good for light mods. It doesn't work on 03-04 civic ecu. E-manage and ems are overkill, and venom plain sucks.
Old Sep 30, 2004
jgoodfella1's Avatar
jgoodfella1 is an unknown quantity at this point
How is the vafc II for those of us with 01-02 models? I have I/H/E and aem pullies.
Old Sep 30, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
VAFC2 works for me. old dyno of 231whp and new estimated 270whp.
Old Sep 30, 2004
gtracing's Avatar
TeLLy is my daddy
gtracing is an unknown quantity at this point
that's weird, i can't get my vtec to kick in properly without the cel coming on with the v-afc2....
i was thinking about emanage, but does anyone think it's actually worth it for a n/a car?
Old Sep 30, 2004
guns's Avatar
Skyline R33
The VAFC works to adjust fuel. The vtec controller portion is only good as a VTEC light or if you do a LS/EX vtec conversion. DO not mess with the VTEC engagement points. It will make you car do weird things. I know from dyno tuning. Stock ECU does not like VTEC changed.
Old Sep 30, 2004
The e-manage has functions you'll never need like timing adjust, injector duty cycle, etc. Plus it's a pain to tune it. Most shops don't know how to do it right.
That's very strange about your vtec. Did you ever get a code reader and find out what the cel number was? That will tell you at least what's wrong.
Old Sep 30, 2004
gtracing's Avatar
TeLLy is my daddy
gerabox, i'm already 4 steps ahead of you...yea, i got it to work once on the dyno, got amazing numbers...but since after that, the cel always comes on...i checked the code and it was just the vtec problem code...can't delete the code, nothing...so i dunno, i'll just leave it as stock i guess
Old Sep 30, 2004
guns's Avatar
Skyline R33
did you solder your connections or use crimps. You have to solder the conections. maybe that is your problems
Old Oct 1, 2004
DodgeNeonSRT-4's Avatar
DodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of light
i've used the greddy system (with the e-01) on different cars and the apexi model. personally, i think they're both very good but I prefer the apexi. once you learn it's complicated system there is really no limit to what you can do with it. and if you got the boost controller they make it looks nice having the two together.
the e manage is easier to use, especially with the e-01 or the newer 02 model
Old Nov 16, 2004
Deadkookaburra's Avatar
Deadkookaburra is an unknown quantity at this point
get obit by cartonics
obit is a great ECU designed for closed looped systems like the newer Civics
http://www.obitasia.com/piggyback_ecu_o-bit.htm
function include: http://www.obitasia.com/function.htm
recorded 15% bhp gain after dyno. i think is impressive for an NA car solely boosted by electronics & simple i/h/e bolt ons alone.
Old Nov 16, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
The AEM ECU is out for the motor, however the multiplex controller isn't functioning at this time.
Old Nov 16, 2004
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
wait a bit and we should have the hondata
Old Feb 13, 2005
kornsined's Avatar
sorry to bring this back from the dead but i've never heard this before.
Old Feb 13, 2005
allmotor's Avatar
nor cal 7thgens
yeah i may stay n/a on d17 lol.........
Old Feb 13, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
im getting ems. and yes there is one for our cars. ems can do more stuff than e-manage. I would go with ems, but only if you have money and the mods to work it. I usually only see higher end vehicles using the ems, such as supras etc.
