DIY Intake (PIC uploaded)
Old Aug 21, 2004
Farage's Avatar
I like you! do you like me?
i am currently leasing a 2k3 EX coupe. i wanted to get some engine mods but didnt want to throw away money on engine mods that i will have to get rid of in about a year and a half. so i made my own intake. i took out the resonator, threw a K&N panel filter into the airbox and ran a 2.75 inch heat resistant tube to a nice cool spot down below with some mesh looking thingy on the end to keep crap out. honestly, i really felt a gain in the low-mid range. the engine sounds alot nicer too. i only spent 10 bucks for the tube that was very hard to find. i wanted to make it really nice so i spent half the day looking for a heat resistant tube. i found it at a local performance shop.
Old Aug 21, 2004
Pics? I took the resonator off and the car was running like crap and making a VERY loud noise like the muffler was broken. No low end at all.
Old Aug 21, 2004
Farage's Avatar
at first i ran it with just the resonator removed. sounded too loud and lost low end power. then i put in the tube and it totally changed. the engine only sounds different at 3-4 k and i definately feel an increase in that range. i am very happy with the tube because its made of like 6 different layers of rubber and foils and there is no heat soaking since it is heat resistant. sorry gearbox, i have no digital camera. ill try to do it with my friends camera but no promises dude.
Old Aug 21, 2004
Oh okay cool. That makes sense, since the tube would restrict and control the flow better than being open. Helps with getting more cold air in as well.
Old Aug 21, 2004
518's Avatar
518
518 is on a distinguished road
I need to know specifically what brand of tube you used.
Subscribed*
Old Aug 21, 2004
zachgeyer's Avatar
lol pixs
Old Aug 21, 2004
Farage's Avatar
i duno the brand. but i will try to post some pics ASAP.
Old Aug 21, 2004
specter542's Avatar
I'm NeonImpact's a55hat!
specter542 should not be trustedspecter542 should not be trustedspecter542 should not be trustedspecter542 should not be trusted
if ur gonna be this cheap, buy one off of ebay.
Old Aug 21, 2004
Farage's Avatar
the point of doing this was to experiment. i know i could have bought one for 30 bucks off ebay but i wanted to see what kind of gains i get. and i can move it around to any spot in the engine to get cooler air. thanks for the wise insight though.
Old Aug 21, 2004
518's Avatar
518
So the tubing size is definitely 2.75? I created a thread a while ago about keeping the airbox and replacing the air filter. I originally wanted an aluminum piping. gearbox suggested it would would draw more heat so my project is on hold.
search: GanzFlow.
edit: Silicone hose is a good idea. But I cant find a website that sells one with the correct bends.
Old Aug 21, 2004
specter542's Avatar
gains...gimme a break.
Old Aug 21, 2004
It's a good idea. The airbox helps act as a plenum for air to keep low end power. The tube is good for airflow and cooler air. Have you checked partsexpress.com for the tubing? They have it specifically for custom intake systems. It molds to whatever shape you want while retaining a circular shape.
Old Aug 21, 2004
518's Avatar
518
I am looking at Silicone 90degree elbows and stright tubes. I need to know what size to use. A 90degree elbow in 2.5" size is $39.99 already. Looking at my engine bay, I would be needing two elbows. Unless I use a 45 degree elbow which will lead directly where the OEM snorkle is. (see pic) I was able to find a 45degree elbow, I might buy two of them and one transition hose. I need to take measurements tho.
I looked into partsexpress.com but my search yield no results. I searched Intake.
Old Aug 21, 2004
I'll post a pic if I come across it. Saw it in a catalog they sent me.
Old Aug 25, 2004
Farage's Avatar
i took a pic of the intake. will post it tomorrow.
Old Aug 28, 2004
Farage's Avatar
here is the promised pic
Old Aug 28, 2004
Farage's Avatar
btw, sorry for the dirty engine and im still experimenting with where to run the tube. also, the blue thing is a slip on plastic piece that has a mesh like thing on it to keep the bigger particles out of the filterbox. where do you think is the best place to run the tube?
Old Aug 28, 2004
usafstud's Avatar
nice to see others making custom items to their car
i think the intake i made is way better. first time making one too.
Old Aug 28, 2004
nikoscivicex's Avatar
www.8thgencivics.com
nikoscivicex is an unknown quantity at this point
Dude... what do you do when it rains?!
Old Aug 28, 2004
prototype's Avatar
x-factor
i would never cut my bumper to make the intake get more air.....good concept but poor planning
Old Aug 28, 2004
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
......hmmm
Old Aug 28, 2004
slvrcivic's Avatar
slvrcivic will become famous soon enoughslvrcivic will become famous soon enough
I agree with him 100%. What happens when it rains for you? You're going to end up sucking water into your engine one day. Then you'll be crying about your dead engine. Not worth the risk on your design.
Old Aug 28, 2004
REDchirp's Avatar
REDchirp should not be trustedREDchirp should not be trusted
He has just as much risk doing that as when all the rest of the idiot car owners with there love and behold SRI's.... and then they wash there car and think its a good idea to shoot the intake filter with water to clean it off then drive it home 5 minutes later.... don't knock it till ya try it guys... i personally won't try it cause of the cost, but i don't think it's that bad of an idea... if he cleaned it up real nice that **** would be bad ***...
Old Aug 28, 2004
Boosting Daily
Who the hells doing that!? Hydrolock only happens when the entire filter is submerged in water
Old Aug 28, 2004
usafstud's Avatar
u dumbshits(nicoscivicex, prototype, slvrcivic)
i'm a fricken mechanical engineer. i planned to cut the hole in the bumper in the first place.
i also track my car, not like all u dumbshits that only street race or canyon run.
i live in souther california. where it only rains like crazy a few days out of the year. also, i still have the stock intake. its only a 5-10 minute job to do a swap. i think its poor planning of you guys not to see where i'm located
Old Aug 28, 2004
usafstud's Avatar
also, there is no way that my intake will even suck up rain. first its going to have to go thru the hole in the bumper. unless the rain is going herizontal, most of it wont get in.
basically, there is no way i can hydrolock unless i submerge my intake into a big *** puddle of water
Old Aug 28, 2004
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
cant see pics.. it says i dont have access to see those pics
Old Aug 28, 2004
518's Avatar
518
run the tube like the OEM.
Old Aug 28, 2004
Wolfgang5884's Avatar
HAHAHAHAHAHAHAHAHAHAHA.....
Old Aug 28, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
Racing Sports Akimoto makes a spiral flex tubing that is insulated to block heat. I know Summit Racing carries it, I'm also sure you could find it elsewhere. Also, that hole in the bumper is nasty, needs cleaning up around the edges, whether or not you track your car. It's still hideous. Also, wouldn't it be more beneficial to make a collector that funnels the air to the intake? Not knocking you, cause I didn't try it, just offering a suggestion.
