?Air Breather?
Old Aug 9, 2004
MIAMIVTEC's Avatar
MIAMIVTEC is an unknown quantity at this point
?Air Breather?
I currently have an injen intake system in my 7th gen. and so yesterday when i went to the shop, the guy handed me an air breather for no absolute reason, along with the intake filter i had just purchased.
i came home and thought: "should i put this air breather on?"
and well? should i? what's it's purpose in life aside from engine aethetics?
Old Aug 9, 2004
CrazyCakes's Avatar
CrazyCakes is an unknown quantity at this point
it vents the crankcase just like the hose did, but now the crappy vapors are actuly vented and not just cycled back into your intake.
Old Aug 9, 2004
MIAMIVTEC's Avatar
do you recomend i put it on? and if i do, how do i plug up the hole in the intake where the hose used to be?
-thanks
Old Aug 9, 2004
Milamber's Avatar
I hate people.
Milamber will become famous soon enough
put it on
Old Aug 10, 2004
CrazyCakes's Avatar
sure put it on. go to the hard ware store and buy a little rubber cap for the hole.
Old Aug 10, 2004
You might have problems passing smog.
Old Aug 10, 2004
civic01vtec's Avatar
don't put it on unless you are boosted
Old Aug 11, 2004
REDchirp's Avatar
REDchirp should not be trustedREDchirp should not be trusted
it actually helps HP if you keep the factory tube in and recirculating back into the intake if your are not Boosted... boosted apps you don't want all that boost pressure going into your valve cover it would make it very hot as welll
mjdiaz89
Jun 21, 2016 09:26 PM
carid
Nov 7, 2015 01:46 AM
NoobyKid
Jul 13, 2015 07:53 AM
