SHORT SHIFTER pls help me
Old May 1, 2004
inperio's Avatar
inperio is an unknown quantity at this point
Exclamation SHORT SHIFTER pls help me
i know there is a short shifter which you change the entire shift stick while there is a short shifter adaptor which uses the stock shift and clamps it right? which is better? does the height of the shift **** lessen when i use the short shifter adaptor? will changing the entire shifter stick make shifting a bit harder or does it still feel like stock? please help me thanks! im choosing between neuspeed or DC which do you think is better? thanx i really need your help in choosing what to buy.
Old May 1, 2004
Ershall's Avatar
Ershall is an unknown quantity at this point
This entire site is biased towards the Revo Technica short shifter for our car. It is a simple install as it replaces the entire shift assembly and a couple members here have made two kits to rid us of some of the "play" in the shifter. I bought my Revo from Rob at RobearRacing...Here's the link: http://www.tornactive.com/cat_civic7.cfm
The majority of 7thgeners on this site use that shifter and it comes highly recommended from us all.
PM me if you need any help.
Old May 1, 2004
Diablo's Avatar
Diablo is an unknown quantity at this point
Revo Technica short shifter its worth the $. you wont regret getting it
Old May 1, 2004
RedEU's Avatar
RedEU is an unknown quantity at this point
i heard that short shifter will damage the syncros, is it true?
Old May 1, 2004
Ershall's Avatar
I haven't heard anything negative about it....search and see for yourself.
Old May 1, 2004
Jrfish007's Avatar
I got the Neuspeed shifter, it's simply an adaptor that bolts onto the stock stick. I was pissed off when I saw it. That means the tranny may not fully enage into the gears and that could ruin the syncros. But I never read up on if it actually affects the tranny or not, I just threw it away I was so pissed at it. Get the one where the whole shift stick is replaced, that won't do anything but make for shorter throws and that doesn't hurt the tranny unless you grind the gears or something.
Old May 1, 2004
SMX's Avatar
SMX
SMX is on a distinguished road
I've had the DC adaptor and the Revo SS. The Revo wins hands down.
Old May 1, 2004
FALKEN's Avatar
Civicforums Junkie
heres my set-up:
Revo SS...RobearRacing
Upgrade Kit...Grey
Aluminum Bushings...CapYoda
works awesome!!
Old May 1, 2004
nunzio42's Avatar
nunzio42 is an unknown quantity at this point
Get falken's setup thats what i have and i love it......cant stand to drive the normal stick anymore.
Old May 1, 2004
Jrfish007's Avatar
sounds nice...
Old May 1, 2004
Diablo's Avatar
I put mine on when i first got my car i now have 20,000 miles and no problem. i think it was one of the best mods ive done yet.
Old May 1, 2004
l00pb4k's Avatar
But it's a Dry Heat
l00pb4k is an unknown quantity at this point
what they all said. Don't waste your money on an adapter. Haven't seen or heard of anyone buying the Neuspeed but it seems like that would be more hassle than just using the Revo and replacing the whole thing. Wanna be the guinea pig, go for it
***does the height of the shift **** lessen when i use the short shifter adaptor?
Not with an adaptor, no. All it does is change the angle that the shift cables attach to the stick. No height change at all.
***will changing the entire shifter stick make shifting a bit harder or does it still feel like stock?
Does NOT feel like stock...otherwise what would be the point? Makes the throws, i.e. the distance between gear engagement...shorter. With a full replacement kit the height of the stick is shorter as well.
Old May 1, 2004
Jrfish007's Avatar
Yeah... I did dig out that Neuspeed adapter out of the trash after I cooled down, if anyone wants, they can have it for shipping cost, I sure don't want that thing on my car.
Old May 1, 2004
nogi1's Avatar
nogi1 is an unknown quantity at this point
revo ss
is the way to go
Old May 2, 2004
inperio's Avatar
thanks for the help. i think ill go for the revo or the neuspeed short shifter not the adaptor. Jrfish007 where are you located? you want to send me the shifter if you dont want it haha. im in CT. do you know where i could get either the neuspeed or the revo around here in CT? what shop has low prices thanks
Old May 2, 2004
Jrfish007's Avatar
I'm in medina Ohio, zip 44256. I'll send it, just PM me and we can swap addresses and I'll send it later this week via UPS if you really do want it.
Old May 2, 2004
Ershall's Avatar
neuspeed is an adaptor........
Old May 2, 2004
born2xLr8's Avatar
Another revo user here Definitely worth the money. Mine was $84 shipped from rob @ robear racing.
Old May 3, 2004
Jrfish007's Avatar
yup Neuspeed is an adapter.... that's sad to , I always thought pretty good of neuspeed. That's why I order the thing, I figured they would know what they where doing, then I got that dam thing in the mail.
Old May 3, 2004
CapYoda's Avatar
Escaped Convict
well I had the neuspeed. it works fine, compared to say DC. at least more solid in terms of install, cuz once u get it on.. its not going to come off via any vibration.
it does shorten the throw, just like the revo.. but the shift stick isnt shorter so it gives less result.
u'll need to drill ur stock shifter to install the neuspeed, so there's a con (or pro in terms of stability of adapter)
neuspeed's fine, the reason why they went with adapter is because thats teh easiest way to change the shift characteristic, and they probably didn't see making the whole assembly as a worthwhile investment (especially when they dont source oversea manufactures, they manufacture their own parts)
and the method B&M went for, cost more and isn't as practical (B&M ss is release pending i believe? or its out already *shrug*)
anyways I had the neuspeed and in like 2 days I got used to the different short throw. or in fact maybe the very same day. I got it cuz I didn't want to reduce my shift height at that time..
eventually i swapped to the Revo and sold my neuspeed. the revo was definitely more fun. although shifting, like many other modification, is personal preference. lots of people prefer the stock smooth shifting, etc. over the stiffer short shifter shifting feel.
even though u're gonna get the neuspeed for free, u'll probably be surprised at how little change it is, and how much of a pain it was to install. lol. thats how I felt, and I paid for it!
as for the bushing, it makes the assembly more solid to the chassis so it gets rid of play in assembly.
grey's kit reduces play in the shifter linkage to the adapter, and extra parts to help the install.
Old May 3, 2004
Jrfish007's Avatar
^^^ he's right. Installation is a bitch, the instruction are not for my car either.
I am currently stock and will prolly stay that way. When I want to shift faster, I simply grab lower down on the assemably, in the boot area. Has worked for me in the past I think it still does.
Old May 4, 2004
inperio's Avatar
do you really need the bushings kit and the upgrade? is there a big difference with these upgrades?
Old May 4, 2004
Ershall's Avatar
^^You don't neccesarily need them, but they are cheap and they make a huge difference from what I have heard if you are looking to eliminate some of the "play." The kits I think are only $26 shipped together and Capyoda and Grey are great about getting them out quickly. They come highly recommended from me and I'm going to out on a whim here and say that the rest of the site recommends using them too. Search for threads where members talk about using these revo upgrade kits...I haven't seen a negative comment yet.
Old May 4, 2004
blouisgod's Avatar
Life Begins > 6800rpms
The revo is straight drop in; it isn't hard to install at all if you can turn a wrench. If you go with the revo, make sure you get the mounting bushings since you will have the shifter assembly off anyway.
Old May 4, 2004
aznsensation18's Avatar
aznsensation18 is just really niceaznsensation18 is just really niceaznsensation18 is just really niceaznsensation18 is just really niceaznsensation18 is just really nice
I have the REVO SS...It is probably the best buy for your money... its easy to drop it... make sure you buy Capyoda and Greys kits...i love it....its the greatest...
Old May 4, 2004
Jrfish007's Avatar
CapYoda is also right that I don't think it will help that muc with shifting. Personally I would just use his set up in the first place and be done with it.
Old May 4, 2004
trust me all you need is grey and capyoda parts they are the greatest
Old May 4, 2004
zen_master's Avatar
REVOSS + capyoda's bushing + grey's kit = the best set of SS for our civic.
the thing is, the opinions all around this website are all biased to the same set...
GolNat
Nov 27, 2018 03:32 PM
Jrosa
Sep 14, 2015 08:24 PM
