What do you guys consider to be the cheapest mods
Old Mar 18, 2004
  #31
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
Originally posted by fo50rd
Guess we are arguing different points. Sure it is not NECESSARY to run higher octane in our engines...however, they can benefit from it. Take a regular ole car to a dyno, make a pull with 87 octane, then pour a can of 104+ in it and make another pull. You will see an increase in power made. I work at a refinery that makes octane, I'm not a kid...and you can noob on dezz nuts.
you don't seem to be hearing me yet again... there is no WAY a car with 104 octane will do better than one deisgned to run with just 87, it's freaking chemestry... the energy potential is the same, NOT to mention an ecu takes over at least a minimum of 1 tank of gas to properly adjust to a different octane level....
Old Mar 18, 2004
  #32
thomusvoo's Avatar
Newbie Member
thomusvoo is on a distinguished road
Renamazazo is going to have an emotional breakdown...
Old Mar 18, 2004
  #33
CivicHX01's Avatar
I'm with u Renamazazo.... manual recomends 86, only 87 is available.. i've never put anything higher than 87 in my HX... all 40k miles have been run on 87 octane... i never gave into their marketing strategies
Old Mar 18, 2004
  #34
JCiv03's Avatar
Originally posted by Dark_Pyro7
Remove the emblems! Its free, Looks cleaner. RSX rear sway. Short shifter.
This sounds good.
Old Mar 18, 2004
  #35
Zzyzx's Avatar
Autocross Junky
There is only 1 benifit for running Higher octane gas in an engine that isnt experiancing Knock.... Better Vaporization. Thats it.
Old Mar 18, 2004
  #36
Renamazazo's Avatar
I have a hard time dealing with stupidity....
However working at best buy means, I encounter it NUMEROUS times a day...
Old Mar 18, 2004
  #37
thomusvoo's Avatar
Newbie Member
me too. i work at a video store and people asked me for movies thats not even in theaters yet.
Old Mar 18, 2004
  #38
02civic's Avatar
Need....More....Mods
02civic is an unknown quantity at this point
I've always used 94 octane in my DX with bolt ons...2 years running and everything seems to be running good. I'm hooking up a nitrous system this spring so i was planning to continue my 94 gas trend. Are you guys telling me that...
1) It can hurt my car by using 94?
2) It can hurt performance by using 94?
3) I shouldnt use 94 for my track days with the 75 shot of juice?
Old Mar 18, 2004
  #39
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
Good question, they same to use higher octane when using nitrous. So that means you drive on when not on the bottle. I run 89, but I did use 93 for a while there, and I have DENSO's so I think that makes a little better spark.
Old Mar 18, 2004
  #40
CiViCLiZeD714's Avatar
the 20 MORE HP chip off of ebay
Old Mar 18, 2004
  #41
Zzyzx's Avatar
Autocross Junky
1. No, just your wallet
2. Possilbly, but probably not (Higher octane is used so you can run Higher Compression levels, Higher compression levels (through engine design/turbo/No2 = More power)
3. Depends, You may need to Run Higher Octane to prevent Detination/knock. you'll just have to try it.
Old Mar 18, 2004
  #42
thecheat's Avatar
thecheat is an unknown quantity at this point
get some lightweight wheels and tires and an rsx rear sway bar. then buy all the "GT" and "TypeR" and "Racing" stickers you can find and add all the weight you just saved back to your car. Or you could jsut do the wheels and sway bar...... yeah, that would be better.
Old Mar 18, 2004
  #43
aznsensation18's Avatar
aznsensation18 is just really niceaznsensation18 is just really niceaznsensation18 is just really niceaznsensation18 is just really niceaznsensation18 is just really nice
Neuspeed upper front strut bar....i noticed a diffrence when installed...only took about 20 mins max...
Old Mar 18, 2004
  #44
blouisgod's Avatar
Life Begins > 6800rpms
Back on topic: Cap Yodas bushings in combination with a Revo SS. About 90 bucks total.
Pimpin Caps Bushings: http://www.7thgencivic.com/forums/sh...hreadid=144413
Old Mar 18, 2004
  #45
blouisgod's Avatar
OooOoO my 1000th post. "Chyeauh Garth."
Old Mar 19, 2004
  #46
Zzyzx's Avatar
Autocross Junky
Suspension modification will yield much more noticeable results then just about any engine mod(baring Turbo/No2 ant the like).
Old Mar 19, 2004
  #47
FuzzBeC00L's Avatar
Fuzzy Boy
Neuspeed upper front strut bar yea its like 70bucks I think do that
Old Mar 19, 2004
  #48
Aznnp77's Avatar
All Show No Go Sedan
Aznnp77 will become famous soon enoughAznnp77 will become famous soon enough
Cheap mods that look nice:
Painted Brake Calipers: $4
Strobe Lights: $10
DIY Grills: $6 worth of mesh
I've read a lot about those ground kits for $40 that supposedly makes lots of difference.
From personal experience I'd have to second, or third or wutever the RSX sway bar. My suspension is so stiff now its almost making me sick.
Tedverseti
Apr 23, 2020 01:45 PM
tylerginevan
Apr 27, 2015 12:29 PM
wsking77
Aug 29, 2001 05:34 PM
