A'PEXi VTEC Air Flow Converter II
Old Feb 24, 2004
  #31
onebuddha1's Avatar
onebuddha1 is an unknown quantity at this point
Originally posted by cwick187
Try putting the Vtec engement on passive like I described in my instructions...It might have something to do with the pressure drop before it engages when set too high.
passive - check
Old Feb 24, 2004
  #32
onebuddha1's Avatar
AWWW!!!
from a different thread
That's good to hear!!! I just ordeered my JDM VAFC II (Silver) from Ebay...I got a good deal for $285...I'm going to sell my Vafc I to my friend with a Integra GSR.
could tha JDM ness of ur vafc be it?
just a thought
Old Feb 24, 2004
  #33
NorrinRadd's Avatar
NorrinRadd is an unknown quantity at this point
Originally posted by gearbox
Everyone that has it has been saying good things about it. I'm getting mine in tomorrow, so I'll let you know how it is without any tuning. Norrinradd said it's only a 6 wire hookup.
Yup, definitely the best bolt-on mod period, when properly tuned at the dyno. Even though I only gained 7whp and about 3-4ft/lb of torque throughout most of the powerband (mid to high especially, low-ends the same), you can feel a good smooth pull throughout and much much better throttle response. I was especially surprised I got such gains considering I only have 2 other perf mods done to my engine (intake and venom, I'm gonna re-dyno without the venom as when its off feels like the car pulls better, want to see if its interfering in any way w/ the vafc2). FYI, yup the hookup is very easy (6 wires, 7 if you need to hookup the vtm due to cel), the hardest part is deciding where to put it (mine's in my glovebox). Gearbox, let me know how your DH pulley and ported head turns out. I think I may want to get them as well, thanks.
Old Feb 24, 2004
  #34
NorrinRadd's Avatar
Originally posted by onebuddha1
AWWW!!!
just a thought
Should be fine, I think the only difference is that JDM will only display km vs. mph and may actually have a knock sensor (did not see this setting or function in the u.s. vafc2 black).
Old Feb 24, 2004
  #35
zachgeyer's Avatar
the vtecs in 7th gens are ivtecs and it diff acordeing to one website and one shop i talked too
Old Feb 24, 2004
  #36
zachgeyer's Avatar
contral wont work on them
Old Feb 24, 2004
  #37
cwick187's Avatar
cwick187 is an unknown quantity at this point
We have Vtec-E for the LAST TIME!!! And it works fine....Search
Old Feb 24, 2004
  #38
WannaBFast's Avatar
Prowlin' with a Purpose
the 01's have just normal vtec....
Old Feb 25, 2004
  #39
Can someone post a pic of where they connected wires? I'm reading the book and it's showing more than 10 different wires.
Should I just use the one Carbonfly posted in tech and just tap those wires? I'm really confused.
Old Feb 25, 2004
  #40
NorrinRadd's Avatar
Yes, use Fly's diagram and ensure the VTM wire is connected. I would recommend against taps and solder your wire connections to ensure proper contact.
Old Feb 25, 2004
  #41
cwick187's Avatar
Solder as Norrin said....If you tap the wires, the connection won't be as good and could cause malfunction
Old Feb 25, 2004
  #42
I'm looking at mine and there's alot more than 6 wires to connect.
So do the other wires just color code to the ECU wires? Like throttle, power, ground...
Also, I'm a bit confused about the initial setup before turning the car on. It says a bunch of stuff to do. Can anyone explain? And we've got 4 cylinders, right? How does the acceleration thing work?
And is it a must to disconnect the battery before install?
Old Feb 25, 2004
  #43
cwick187's Avatar
you should just take it somewhere if you can...It kinda seems to be over your head a bit. I really don't mean that in a smartass way, it's just that you can really screw your car up if you don't know what your doing.
Old Feb 25, 2004
  #44
NorrinRadd's Avatar
Your're right, there's 13 total and you'll need to connect 11 of them (everything but VTC and TDC). My bad, my post on the 6/7 wires were wire types/functions (Power, Ground, RPM, Throttle, VTM, VTEC, and Pressure) and not actual total as there are input and output wires for ground, power, vtec, etc. The vafc2 wires don't color code to ecu wires you'll have look at the plugs and eyeball which wires are what, just follow their added diagram and you'll be fine.
As far as initial setup...
Just before doing initial setup, while turning ignition on press gas pedal down for 10 seconds, then release for another 10 seconds before moving on to initial setup settings step. This step takes care of step 6 below...
1. Sensor = 06 & 06
2. Cylinders = 4
3. Throttle Voltage = automatic
4. Throttle Type = Arrow pointing NE
5. VTEC Type = 1
6. See above...
7. VTC = N/A
8. Turn off ignition and your settings get saved
*** Yes, you must disconnect the negative battery terminal before installing the wires!!! You're working w/ lower gauge wires and more power compared to lights and one crossed wire could fry your ECU (during the wire connection process). Sounds scary, but just disconnect it and make double sure which wires go to what. You'll be fine, just PM me if you have any other questions.
cwick is right though... if this seems overwhelming just take it somewhere to get installed as you don't want to fry your ecu if your unsure about the process. APEX-I shops are few and far between, but most dynos that tune vafc2's will install them as well.
Old Feb 25, 2004
  #45
Thanks for the info. I'm just not clear on where the other wires go that are not in the diagram.
EDIT: Sorry, I'm stupid. I just realized some wires are doubles that connect to the same ECU wire. Okay, so I'm just following the wire diagram. THANKS!!
Hopefully later tonight I can get this to work. My mount is almost done.
Old Feb 25, 2004
  #46
Anyone have pics of their install? I just tried my mount and it's not fitting right. Now I need to rethink this.
Old Feb 25, 2004
  #47
cwick187's Avatar
I had one, but I had to format my Comp. I just used the mount that came with the VAFC and put where my cup holders are (or right above them)
Old Feb 25, 2004
  #48
WannaBFast's Avatar
im planning on tuckin the wires back
Old Feb 25, 2004
  #49
Cool. I think I'm just gonna put it in the glove box with the original stand. It really doesn't match my interior lights at all...
Old Feb 25, 2004
  #50
mlovela's Avatar
mlovela is an unknown quantity at this point
Just started reading about these, are they worth the coin? How easy are these to adjust without having to spend money at a Dyno shop? Are they ment to use on a stock car or more if you have bolt ons, intake exhaust?
Old Feb 25, 2004
  #51
WannaBFast's Avatar
well.. if you have an air/fuel meter, you can sorta get in the area where you want, but i think its worth it, it gives the most proven hp out of any other mod you can do for that price...
Old Feb 25, 2004
  #52
zachgeyer's Avatar
what kind of stan dose it come with. Can i unpluge it and dosent it come with a case like for a cd face plate .
Old Feb 25, 2004
  #53
zachgeyer's Avatar
what about a Apex AVCR II ???
Old Feb 25, 2004
  #54
zachgeyer's Avatar
When its unpluged/turned off will it go back to stock seting
Old Feb 26, 2004
  #55
I just installed mine. Not very happy cause I couldn't solder connections. Had to use stupid splices that suck and I hate electronics. Well, hopefully it stays good. It's so freezing cold outside and I was doing this for a couple hours.
Anyway, I guess it's working. I took it out for a spin and everything seemed to be working for the monitors and stuff.
Thanks again everyone for the help. Once spring comes around, I may redo the connections. There's just so little space back there!!
And no I didn't feel any gain. It's all stock settings, and stock car. Just glad it's working properly.
Oh to answer the questions, once it's plugged in, it stays plugged in. Also, it saves your settings when ignition is turned off.
Mine's just sitting in the glove box, but I'll post pics once I get the mount put in.
Old Feb 26, 2004
  #56
Here it is mounted with the Apexi stand, and then with the custom glove box removable cover.
Old Feb 26, 2004
  #57
zachgeyer's Avatar
dose it vodi warrtey
Old Feb 26, 2004
  #58
I don't think so, since it's pretty much like any other intake/exhaust type mod. The only way would be if it somehow messes up the car. Then it wouldn't be covered, since the aftermarket part caused the problem.
Old Feb 27, 2004
  #59
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
how does the vafc differ from the avc-r?
Old Feb 27, 2004
  #60
cwick187's Avatar
Yes, it will void the warrenty...Anytime you install a mod that lets you adjust ECU settings or etc..
