More HP???
Old Jan 15, 2004
TypeRCivicBoi19's Avatar
TypeRCivicBoi19 is an unknown quantity at this point
Arrow More HP???
I have a 2002 HX, and i've put a AEM short ram intake, aerospeed header, and muffler. I want to add more hp... but don't know whether to do pulleys, cam gear, cams? I'm willing to spend the money... but don't want to spend it for nothing... i want something worth my money!
Old Jan 15, 2004
Zzyzx's Avatar
Autocross Junky
Do you just want more HP or do just want to go faster....
Because you dont nessisaily need one to do the other.....
Example: heres some cheep acceleraion for you. Run "short" tires. Like a set of 205/50-15s. what this does is shorten the final gear ratio of the car giving you quicker acceleration at the cost of top speed (Who actually needs top speed any way?)
Old Jan 15, 2004
It looks like you already spent it on nothing. Maybe you gained a few hp from all of that and lost some low-end power in the process.
The most promising cheap mod now is the DH-racing crank pulley. The whole intake/exhaust thing doesn't work on our cars.
Old Jan 15, 2004
Entropy's Avatar
Entropy is an unknown quantity at this point
SF turbo kit, that'll give you hp and won't be a waste of money.
Old Jan 15, 2004
DistinctiveBP's Avatar
Shows No Remorse
DistinctiveBP is an unknown quantity at this point
i agree. and i have heard nothing but, good things about this kit.
Old Jan 15, 2004
... and where do i find this SF turbo kit?
Old Jan 15, 2004
cambo's Avatar
I wish I was asian
in our forced induction forum
Old Jan 15, 2004
CapYoda's Avatar
Escaped Convict
from an HX! yikes. its hard enough with no power. you dont need the complication of an economy tunned engine.
Old Jan 15, 2004
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
or you could go n/a instead of turbo. More expensive, but a different approach. Check out www.dh-racing.com . You could get a PnP job, intake manifold, new valvetrain (valves, springs, retainers, camshaft), and maybe some 10.8:1 pistons. It's all about your personal choice. And yes; if you want a fast car, new tires are a must.
Old Jan 15, 2004
whitebread's Avatar
whitebread is an unknown quantity at this point
I agree with Jwalker on this. Everyone's doing turbo. Im trying to make my EX pretty fast without FI. Those boltons would be more effective with some internal work and maybe a shot of laughing gas.
Old Jan 15, 2004
ImportRacer2123's Avatar
K20 Member
i have laughing gas
Old Jan 15, 2004
YS's Avatar
YS
YS is an unknown quantity at this point
Originally posted by gearbox
...The most promising cheap mod now is the DH-racing crank pulley....
but it'll bypass the PS and AC right?? do they make one that does not bypass the ps and ac???
Old Jan 15, 2004
Yes they do. It's the dual groove pulley in the group guy. It's now down from $185 to $155! Has two grooves and you just need to buy new belts to use the A/C and PS. I already ordered one.
Old Jan 16, 2004
YS's Avatar
YS
where did you find for $155??
"... $15 off dual groove crank pulleys ($185 to $175 after discount) ..." <<-- that one???
Old Jan 16, 2004
IronFist's Avatar
I wouldn't necessarily get smaller tires. It will throw off your speedometer and odometer. To me, those are important. Other people disagree, tho. You could get lighter rims but that's expensive and you won't notice much in terms of acceleration.
I'd say the pulley from dh-racing is your best bet, if it turns out to be as awesome as everyone says it's going to be.
Old Jan 16, 2004
CPEasy02's Avatar
CPEasy02 is an unknown quantity at this point
get the pulley and a sf kit....then just lighten the car as much as possible...that will give you hella acceleration and hp at least for our civics anyway
Old Jan 16, 2004
nspice's Avatar
nspice is an unknown quantity at this point
Well to tell u the truth, if u said ur willing to spend the moeny just drop a k20 b/c ur really not gonna get anywhere with out d17s.
Old Jan 17, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
here are somestuff u can try
- take out spear tire
- pulleys (100% sure ur car will go faster)
- take out power steering belt
- deduct more weight of ur car
Old Jan 17, 2004
jwalker87's Avatar
Bodacious Member
take out rear seats...biiiiig waste of weight
Old Jan 17, 2004
Elite's Avatar
Elite is an unknown quantity at this point
the seats are almost made of styrophome and carpet I dont see how that is saving weight. I think the most effective is replacing trunk and hood with carbon fiber
Old Jan 17, 2004
If you really want to go hardcore, take off the factory sound deadening. That stuff is heavy and it's all over the place. It doesn't help at all for road noise. I should have done that before adding dynamat and stuff.
Old Jan 17, 2004
civicdude04's Avatar
civicdude04 is an unknown quantity at this point
venom 400, got mine for $220, helped out quite a bit
Old Jan 17, 2004
Da1lyDr1ver's Avatar
actually, the hood and trunk arent as heavy as you think. i know when i replaced mine with carbon fiber.
Old Jan 18, 2004
IronFist's Avatar
Yeah, doesn't a cf hood for us only save like 15lbs? That's nothing. That's like 3 gallons of gas or something. I mean, it's helps, but you're not going to notice it I don't think.
Old Jan 18, 2004
Marcus's Avatar
And Pimp I got the Juice
Marcus will become famous soon enoughMarcus will become famous soon enough
can u use the venom 400 in a LX?
Old Jan 19, 2004
Zzyzx's Avatar
Autocross Junky
every oz. counts, especially with a low HP car.
Old Jan 19, 2004
CoupeStylz's Avatar
Si(R) killer # 1
CoupeStylz is an unknown quantity at this point
I see you have intake and exhaust, so you should get a high flow cat to maximize the flow since you're still pushing it through the puny stock cat and associated piping.
Old Jan 19, 2004
jwalker87's Avatar
Bodacious Member
thats true...or at least the cat. The piping in the downpipe is actually pretty large...but if your state allows you to get an aftermarket cat, go for the Random Technology. They're CARB legal and very high flowing.
