42 Volt Electrical Systems and the advantages
"About 40 years ago automotive electrical systems moved from a 6-volt standard to 12/14 volts. Now the change to 42-volt systems - which use a 38 volt battery and 42 volt alternator output - is being proposed."
That's what this is about...the upcoming 42volt standard. I was posting in another thread about electric supercharging and thought this would be a great topic to discuss.
I have read about some of the new designs using hybrid systems like the Honda Hybrid and Toyota. But they're going much further in the upcoming designs with better batteries and higher voltages.
One article I read in Popular Science or Popular Mechanics was talking about combining the alternator and starter into one unit on the driveshaft somehow. This would start the car and also act to recharge the batteries once the car was in motion. I can't find the article or I'd give you a specific example.
I found this page today and it has a lot of interesting info about the advantages of 42v.
http://www.autospeed.co.nz/cms/A_0319/article.html
I see the most beneficial changes to us as being feasible electric supercharging, better audio/video systems, amplifier improvements, and incredible new lighting.
Here's a list of the advantages from that page:
Electric power steering - More power, improved fuel economy
Electric brakes - Redundant power supplies
Power windows, power seats, power hatchback lifts - Reduced size and mass of motors; more efficient operation
Heated catalytic converter - Lower emissions; quicker light-off time
Heating, ventilation, airconditioning blower motors and cooling fans - Greater efficiency; smaller/lighter units; flexible packaging
Mobile multimedia - More power available for video, mobile phones, navigation systems, audio amplifiers, fax machines
Electric water pumps - Improved efficiency; longer service life
Selected engine management system components (eg exhaust gas recirculation valves, ignition systems, control actuators) - Reduced size and mass; increased performance
Fuel pumps - Reduced size and mass
Heated seats - Faster heating, more efficient operation; increased power
Electric supercharging - Higher engine efficiency
Ride control systems - Improve ride, handling and vehicle stability
Brake by wire - Improved vehicle packaging and vehicle performance
Steer by wire - Enhanced performance; improved packaging; improved passive and active safety
Electromagnetic valve control - Lower emissions; optimal power; individual cylinder control; lower cost
Integrated starter/generator - Faster starts; quicker charging; design flexibility; low noise and vibration; improved fuel economy
I found the info about the starter/alternator idea on that site I listed above. Here's a quote:
"However, probably the most dramatic development in alternator technology is the Integrated Starter Alternator Damper (ISAD) being developed by German company Continental ISAD Electronic Systems GmbH & Co. The ISAD combines the function of a starter motor and alternator into one assembly that is located between the engine and gearbox. ISAD is able to generate output voltages of 12, 24, or - significantly - 42 volts. The device eliminates the:
* conventional starter motor and solenoid;
* flywheel;
* conventional alternator;
* alternator pulley and belt drive system;
* and in some cases, the harmonic balancer."
One of the big advantages I see, if internal combustion engines are still being used, is the lack of many belt-driven accessories that drain engine horsepower. That is some cool sh*t!
* flywheel;
I like the idea of removing the parasitic belt losses. Under normal driving conditions the electrical system can pull energy off of the drivetrain. However, under WOT, the system would take nothing. This could (in some cars) be like adding roughly 25 Horsepower.
With all of the weight saving mentioned above, we could see a VERY dramatic perfomance increase in even economy cars.
jferristx
Jul 8, 2015 10:09 PM
42, 42volt, accesories, advantages, alternator, alternators, batteries, car, derived, electric, electrical, explain, hybrid, system, systems, volt
