Just ordered a K&N FIPKII
Old Dec 9, 2003
evanl85's Avatar
evanl85 is an unknown quantity at this point
I decided it was time to upgrade my intake from my AEM SRI to the FIPKII. I've read mainly nothing except good things about the intake. Is the install any harder than the AEM one? I know the hardest part was getting the stock airbox off, but I don't have to go through that again. Also, does anyone have it on an 03? For whatever reason it is only listed up to 02, but they are the same engine, so I can't see why it wouldn't fit. Thanks
-Evan
Old Dec 9, 2003
JayFReaZy's Avatar
where'd u get it, and how much?
Old Dec 9, 2003
evanl85's Avatar
Dezod hooked me up, you should PM him for a price if you are interested.
Old Dec 9, 2003
cwick187's Avatar
cwick187 is an unknown quantity at this point
The K&N is awesome!!! I had the AEM Cold air and there is a big difference in the low -mid range power...Good Choice..The install is so simple as well
Old Dec 9, 2003
evanl85's Avatar
During the install did everything fit like it should?
Old Dec 9, 2003
civicvtec1ps's Avatar
Search and Learn
Intake should fit without any problem on 03 civics.
Old Dec 9, 2003
JayFReaZy's Avatar
just wondering, does an intake really matter in an auto? I was thinkin either injen sri, or k&n fipk II? Will either one matter? I herd nothing but good things about the k&n, but will its performance actually apply to me?
Old Dec 9, 2003
IronFist's Avatar
^ The engine on an AT sucks in air the same way the engine on an MT does.
evanl85, everything fit perfectly. The hardest part is getting the padding around the heatshield.
Old Dec 9, 2003
VTECTypeR's Avatar
Either way your not gonna feel the performance. Intakes a intake
Old Dec 9, 2003
dacivic's Avatar
dacivic is an unknown quantity at this point
Yea thats the hardest part, everything else hit perfectly.
Old Dec 9, 2003
evanl85's Avatar
I guess the heat shield isn't wrapped at first then? Guess I'll see how that works when I get it.
Old Dec 9, 2003
one for the kid's Avatar
one for the kid is an unknown quantity at this point
i don't know about other intakes, but with the FIPK, i felt the performance as soon as i took my car out for a test drive. it picked up a lot quicker and no it wasn't just my imagination. even my mom noticed it right away and i didn't even tell her that i had installed it.
good choice evan!
Old Dec 9, 2003
Flashlightboy's Avatar
Flashlightboy is an unknown quantity at this point
I called K&N yesterday and learned that although their site only shows it fitting 01 and 02, the FIPK is in their computer for the 03 too.
Old Dec 10, 2003
evanl85's Avatar
I called K&N also, but they said it won't fit the 03, or it would be in the system. What gives? She doesn't know *why* it won't fit, just that it would be in the system if it did.
Old Dec 10, 2003
HomerSimpson's Avatar
evanl85 the install is very easy, hardest part was taking out the stock airbox.
Old Dec 10, 2003
doubledeuce2k2's Avatar
took an hour and a half, my first intake install ever.
Old Dec 10, 2003
evanl85's Avatar
Does anyone have this installed on an 03? I know it *should* fit, but I want to know if anyone has actually done it.
Old Dec 10, 2003
Just got mine this afternoon and I'll do the install this weekend on my 03. I'll post the install details when I'm done.
On a side note, I was inspecting the plastic tube and in particular, the end that attaches to the throttle body. About 2 inches in there is a hole that has fiberglass insulation in it. Some of the fluffy stuff is sticking out into the tube itself.
I pulled some of it out but I'm concerned that my engine is going to suck some of this stuff into it's tummy.
The hole does not go all the way through but rather seems to be a fill spot or for the molding process. It's about the diameter of your pinkie fingernail.
Any else have this problem? Or is it a problem at all?
Old Dec 10, 2003
evanl85's Avatar
That seems odd, does it look "broken" inside? I don't have mine yet so I can't check, maybe some of the others who have it already know?
Old Dec 10, 2003
It doesn't look broken but it seems to be a fill spot where a layer of insulation is on the tube itself i.e., a built in heat shield sandwiched between the outside and inside walls of the tube.
It looks like the the fill hole was never covered up but it very clearly is a hole with fiberglass like stuff sticking out of it.
Old Dec 10, 2003
evanl85's Avatar
Well, I'll have mine within a few days, I'll look for that also.
Old Dec 10, 2003
Anybody have a tube answer?
Old Dec 11, 2003
VTECTypeR's Avatar
Thats where ur MAF gos. U take the plastic piece off from you stock intake and put it in your new one
Old Dec 11, 2003
Master's Avatar
Banned by Admin
hey people, are you stupid everything in the engine bay is the same from 01 to 02 to 03 to 04. It will fit.
Old Dec 11, 2003
Vtec,
It's not that hole. This is is one that is another inch or so further inside the tube. It doesn't go all the way through the tube but rather only half way. Inside the hole is fiberglass and I can pull out quit a bit with some tweezers.
Old Dec 11, 2003
UPDATE:
I called K&N this morning and the service tech said that it was a defective part and that fiberglass isn't supposed to be part of the intake tube.
Old Dec 11, 2003
DistinctiveBP's Avatar
Shows No Remorse
DistinctiveBP is an unknown quantity at this point
send it back and get a new 1
Old Dec 11, 2003
A new one is on the way!!!!!!
Old Dec 11, 2003
ThsUserNmIsDumb's Avatar
Currently boosted at 0 psi.
ThsUserNmIsDumb is on a distinguished road
So far, I've been looking at the AEM V2 and the K&N FIPK II, but I was lead to believe that there is really no big difference. I personally wanted the K&N, but the price tag suggested I go with the AEM. What do you guys think?
By the way, I have an 03 EX. Thanks.
Old Dec 11, 2003
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
get the RD CAI . you can get it for like $60 on ebay and the sound is awesome. And it looks really cool with the cf-look cold air shround on the cone filter.
