should i buy this
Yeah, i drive an EP
should i buy this
so what is everyones opinions on this.....should i buy it...???
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2441386118
it seems pretty cheap, why not? i've heard someone say on this forum before that the crank pulley can cause premature wear on your motor, but have no idea if its actually true.
I wish I was asian
Originally posted by DhRacingJosh
Yes but you also have the extra 150 lbs that your AC and Power Steering consist of. Also our pulley is 6 Ounces not 6 Lbs like stock, thus meaning 6000 Lbs when in full motion at 7000 RPMS, so you can see where the power comes from. It's the same thing as doing a perfectly balanced lightened flywheel, you shave off weight which makes the crank pull quicker, and produce much quicker acceleration.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
viperGTS
Jul 27, 2015 08:38 PM
