Question about a cold air intake...
ok, I don't know wtf happened there, but i'll retype it in. OK, I have a injen cold air intake. I read that if you drive in wet conditions it could suck water into the engine causing massive failure and damage. Is this true? And if so, how do I lock it off to prevent this? And how severe do the wet conditions have to be in order to suffer this problem. thx for the help.
the problem is called hydrolocking, you can stop it by buying a by pass valve but u are going to have to cut you intake to install the valve. you have to go through a large enough puddle where your entire filter is submerged and then you would have to give it some gas to open the throttle body and pull the water up.
btw, search first. this has been covered numerous times.
OK... look, here's the deal. If you're dumb enough to drive through water deep enough to completely sink the filter and still keep your foot on the gas, you're gonna suck in water, and you deserve to hydrolock the engine. But unless the filter is completely submerged in water, the bypass isn't going to do anything. I've driven in 5 or 6" of water and not a damn thing happened. The filter is protected in there, so it should be safe provided you use your head while driving.
A descendant of 2k1civic.com
Yeah. . if the water starts getting in excess of 4 ft deep. . A Civic isn't the right vehicle for that application. It's more preferable to run a boat in that situation.
well said!!!!!!
mrohitredd
May 30, 2015 06:51 PM
jc33312
May 12, 2015 03:17 PM
tylerswire
May 6, 2015 12:16 PM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
