Engine Performance Modifications Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here
answers needed please
Old Mar 28, 2013
eafreeworld's Avatar
eafreeworld is an unknown quantity at this point
Ok so im new into the honda game nd dont know much about it first question is what kind of transmission do i have my car is a 95 civic it says eg8 on vin almost sure its a lx sedan since i have pw pl nd no sunroof my tranny its a 6 speed nd i want to know whats the name of it second question is the car is suppose to have the d15b7 but has a d16y7 i want to know what engine would be better since im not getting that much power with this one thanks for looking nd your time looking fwd ur answers
Old Mar 28, 2013
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Re: answers needed please
Displacement (cc):
1593
Power (bhp@rpm):
106 @ 6,200 rpm
Torque (ft/lbs@rpm):
103 @ 4,600 rpm
Compression Ratio:
9.4:1
Bore (mm):
75
Stroke (mm):
90
Cam Design:
SOHC
Valve Train
no
You can check engine Specs here http://www.jdmenginesamurai.com/engines/honda.htm
What month was your car made? the engine type you said is usually found in the 96-00 model.
Check here for your Tranny specs.
http://hondaswap.com/reference-mater...n-specs-29132/
Old Mar 28, 2013
Thanks for ur answers im still confused i just bought the car i guess previous owner swap that engine nd tranny in there since only the rsx ep3 nd crv k series have the 6th gear tranny nd like u said the engine is for a 96 00 model but im still wondering what other engine could i put if i am not getting the power i want thanks
Old Apr 8, 2013
Gunner's Avatar
To be honest I am not sure what you are looking for. Its a civic. people add boost, some models now have superchargers but, when looking at a compact car power is not usually that high.
What kind of power are you looking for. Si motors have more HP than standard..
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
Myredjonda
Apr 14, 2015 07:00 PM
GabberHead
Nov 20, 2001 07:32 PM
