New Owner, lots of questions
I just bout a 1995 Civic Del Sol for $2,000 and want to make it my project car. I have a laundry list of things I want to do but I don't know where to start. I plan to put a new engine in, but I have no idea what kind, size or where to even start looking.
Kenny the Ricer
Re: New Owner, lots of questions
Let me tell you this first, we are only going to help you if you are honestly trying to make it a project car.
Try to learn a bit about engines and how turbos work first
If you say "I want to put a LS1 in here, with 20psi of boost", please get out now
With that out of the way,
What is a priority in your books?
Paintjob?
Interior?
ICE?
Speed?
Del sols arent meant to be fast either, just like civics, if u wanted a little more speed out of it, should have gotten a lude.
Please post pictures of your new ride, and maybe we'll be able to help you.
Paintjob?
Interior?
ICE?
Speed?
Live for the Twisties
You need to look at your budget and goals, then go do some crazy research.
An engine swap could run anywhere between a $1000-$15000.
My first priority is performance. I'm not trying to do some fast and the furious crap but I would like to be able to get up and go when I'm feeling antsy. I have no idea what you where even talking about with the PSI boost or what ever.
Kenny the Ricer
Who said you needed to do a RWD conversion?
Thats just part of mind's signature
I'm not positive, but i'm pretty sure you can stuff a lude engine in a del sol with some modifcations.
a bit of header/catback/intake will give you good sound when you hit the gas.
That's all you should do performance wise, del sols arent exactly aerodynamic
Kenny the Ricer
Yes, Prelude
I'm not exactly sure on which engine and how it all comes together, as i'm not an engine kind of guy, maybe someone else might be able to answer those questions
do you want all around performance or fast in a straight line?
straight line, an H22 would do you good. It's heavy, but it'll give you hella pep to your step. With the weight of the engine, it'll hinder handling, hence the straight line emphasis.
For all around performance, a B16 or B18 would be your best bets.
It's not like a H22 would be too much for everyday use, it's just a heavy engine, so your handling would be slightly compromised.
If you could find one for cheap, i'd rock a B18C5 in it (Integra Type-R)
Welcome to the forum. For Del Sol Sexiness, look here:
http://www.k20a.org/forum/showthread.php?p=416727
http://www.tunedbylorange.com/h22delsol.html
http://www.flickr.com/photos/bgcanon/3693383872/
Do ANY of these swaps, and you del sol will be FaSt
start first from the suspension/brakes/tires. They are what will keep you in contact with the rest of the world.
define an idea of the engine you will likely to put in and then you will have an idea of the suspension you will need.
By suspension, i am also referring to the normal maintenance, likely ball joints, bushings, if something is broken, lubbing, sway bar endlinks, etc, etc.
Keep in mind that we are mainly civic's.
I've seen it done before, but there really is no point to a K20a del-sol unless your looking for something show quality and money's no object. Remember, unlike an EM2, you can swap a H22 into a del-sol and a type R H22 is 220hp just like a K20a.
ok first heres some possibilities BESIDES engine swaps that could really give your car some push.acceleration i found is a key component majority of the time.first, Full cat back,try to get a custom job and get the pipes as straight back as possible.while thats going on,you could get high flow cat,custom headers,custom exhaust manifold,wider throttle body.customize your fuel delivery for better fuel injection.bump up your ignition like msd is a good brand.new flywheels,upgrade clutch assembly and/or tranny.as for engines i would have to agree with the h22 or k20 they both push and you can use them in your everyday car
just fyi.. the d-series only has a single exhaust manifold.. and it would be counter productive to get a custom header and exhaust manifold.. just sayin.
also, if you don't have adequate backpressure, the engine will perform like crap
A customer header and exhaust would be insanely expensive compared to a production equivalent and it is completely unnecessary. A larger exhaust often results in inadequate back pressure on an engine with just a couple bolt ons, so all it does is add unnecessary weight. You need a good EMS before you can expect any real performance from adding larger injectors, intake, exhaust and such.
This thread is pointless though, the owner needs to figure out what there budget is and what exactly they plan on doing before the come start asking questions. I'll paint my car with purple house paint if I see the OP drop in a K20a, no offence guys.
I'm very new in this forum and I'm hoping to get the right answers. I'm in Los Angeles CA.
I was handed down a 97 Civic DX, to cut the chase, I just want to add more horsepower in it, I have no plans to race it, I just need more horsepower in a non expensive way. Pls. advise what to do and where to go to get it done. Thank you.
