Engine Performance Modifications Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here
Defective circuit/ fuel injector Need Help
Old May 14, 2008
Crazeycoop's Avatar
Crazeycoop is an unknown quantity at this point
Okay, I have a 90 Civic Hatch with a d15b1, dual point injection. Recently I swapped motors beause the old one went out. Almost everything that was on the old motor is now on the one in there. Once I got it running, I took it out for a test drive and everything worked fine. I stopped by a carwash and in the process i went ahead and sprayed some of the motor off too. When I left the car wash I went to gas it and it stalled a little bit and the check engine light came on. Once it came on, evertime i try to get in higher RPM's, dont have a working tach, around maybe 4000 it stalls and won't accelerate anymore. My ecu spit out code 16 which is defective circuit/ bad injector.
I dont think that it is an injector because it is the same injectors I was using before. Plus, I went to a junkyard and pulled the whole top part of the intake and swapped it out and it still does it.
Also, when I first got the car, I bought a little mod that hooks up to some wires and I wasnt too mechanical then and I spliced my injector wires and put it on there, but fixed that almost immediatly. It had worked fine rewired with electrical tape for the past three years, but I thought maybe during the swap the connection got bad so I respliced it and made a better connection. After that I drove it around for a few miles and gassing it hard when I could and everything worked fine. The next morning, I went to go to work and it started doing it again. So I disconnected it again and got some wire connectors and redid it making sure the connection was about as good as it can get and it still did it.
I have tried swapping injectors, making a better connection, and cleaning the connectors but none of that worked. What is the circuit, and where is it? I also have noticed that when the car is in gear and I start moving I hear like a sparking sound under the dash on the driver side. It sounds like two wires making a connection kind of like when you hook up a battery cable. It doesnt do it all the time, but my lights on my dash will flicker when it does it.
The car runs and idles fine. And if I reset the computer and start it up, I can rev it as high as I want and nothing will happen, nor will the check engine light come on. But when I am driving and i let the RPM's get too high it stalls and the check engine light comes on. It will still drive fine, I just can't get the RPM's up, kind of like a newer car that shuts off after a certain speed, when the RPM's get so high it just boggs. It wont even let the RPM's get up high in nuetral once the light comes on. PLEASE HELP!!!!
SimpleUser
Apr 24, 2021 02:54 AM
GritzNGravy
Aug 19, 2015 03:03 AM
martinsmartin
Aug 15, 2015 07:34 PM
fred57
Aug 1, 2015 08:45 AM
Green02civic
Jul 27, 2015 10:48 PM
