Engine Performance Modifications Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here
need help ASAP
Old Aug 16, 2007
93sir's Avatar
93sir is an unknown quantity at this point
need help ASAP
I just turboed my b16a2 motor, i want to look everything over before i turn the key. What should my cams be set at: right now they are at -2,3 degrees, also what should my fuel pressure be for each PSI right now im running 42psi..Im trying to run 8psi of boost.
Old Aug 16, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Re: need help ASAP
Need way more information that that.
Its going to need to be tuned before you can really run any sort of sustained boost through it, and your tuner will get everything where it needs to be.... so as far as everything is concerned.... fire it up and make sure it starts and then go get it tuned.
Old Aug 16, 2007
JustinSane's Avatar
JustinSane is an unknown quantity at this point
Re: need help ASAP
i agree a good managment system is also a good idea, CHROME or hondata ect ect , 8 psi isnt much boost but with no tune you dont know if your lean or not at WOT.
