Engine Performance Modifications Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here
Automatic To Manual Swap
Old Jul 27, 2006
ss5wil's Avatar
ss5wil is an unknown quantity at this point
I have a 95 Civic EX 2 door coupe I want to put a B series engine and trans but my car is an automatic and I want a manual trans. What parts would I need besides the trans and is it pretty much a bolt on conversion?
P.S. I have alot of history with this car and buying one that's manual is not an option!
Old Jul 28, 2006
05blkrs's Avatar
05blkrs is an unknown quantity at this point
youwill need:
tranny
axles
starter
shift linkage and shifter assembly
clutch
flywheel
idk about a civic but on a 240 sx you have to change this little bearing in the back f the crank... but i dont think honda requires changing it...
clutch pedal assembly
brake pedal assembly
clutch master and slave cylinders
clutch lines
you will also need the 5sp ecu or you will shoot out check engine lights like no body's business...
you will also have to do some re-wiring as far as the sensors that go to the tranny are concerned.. also, you'll have to rig some switches in the auto shifter/ignition systems... i'd buy all those major parts and have an experienced tuner do the work.. it's not hard if you've done it before, but attempting it by yourself w/o experience isnt' smart
Old Jul 28, 2006
Shishpanik's Avatar
Shishpanik is an unknown quantity at this point
I think you're killing two birds with one stone cause when you buy an engine with a transmission youre gonna have to swap the tranny anyways (unless you want really weird gearing).
97-DX-Lover
Jun 14, 2015 06:07 PM
cruisers10
May 12, 2015 10:46 PM
oneheadlight
Apr 29, 2015 11:30 PM
McD
Apr 22, 2015 05:28 PM
SgCivic
Bolt-on Engine Performance
Nov 15, 2001 07:31 PM
