Replaceing a Rack and Pinion on a Civic EX 95
Old Jun 3, 2010
borntowander's Avatar
borntowander is an unknown quantity at this point
Are there any instructions on how to replace a rack and pinion on a 1995 Honda Civic EX out there??? Or even a site that can show me how to.
Thanks
PS Need help!!!
Old Mar 5, 2011
eg from hell's Avatar
eg from hell is an unknown quantity at this point
Re: Replaceing a Rack and Pinion on a Civic EX 95
i just replaced mine, but i had the motor out. its best if you can put your car on a lift, or jack stands if you have to. if you have never done it before, its just time consuming. couple hours if you have all the right tools. its self explanatory, then you need to remove one bolt underneath your steering wheel the connects it to your steering wheel.
remove wheels, locate the nut you need to remove and take out pin before you try to take it of. then there are 4 bolts that go into your fire wall that are holding it on.
you need to drain all your fluid too or just cap it off.
after everything, get an alignment! i still havent and im eatin through tires because my toe is jakt. i run a tattoo shop and dont have time to be runnin around or being without a car
GH04si
Apr 15, 2015 08:13 PM
thesushiboy
Apr 12, 2015 02:54 AM
toastyghosty
37
Jun 10, 2002 01:07 AM
veloce
Nov 10, 2001 01:19 PM
mattskav
Nov 8, 2001 10:44 PM
