Voltage Problems!
Old May 24, 2015
MiniMi's Avatar
MiniMi is an unknown quantity at this point
Voltage Problems!
Hey guys im just here going nuts.
I got a 95 dx d15 with d16 vtec head
Last two rainy days we had my voltage would spike way up then way down finaly killing the battery, once it dried up outside everything whent back to normal.
Now today was realy sunny and i lost voltage and killed my battery (battery is brand new, alternator is 2 months old).
There is no cel or battery light on any anytime, even when you cycle the key only the engine light and oil light come on (normal?)
My worst fear is something burnt out during the wet weather voltage spike, or eld is dickering me. (which i cannot find {just had fuse box apart})
also i cleaned and replaced all grounds
Cleaned and inspected all positives
Checked alternator conections
Checked every indevidual fuse in the car
Let the car cool and tryed with no luck
Any ideas would be amazing, thanks
Old May 25, 2015
Poopies's Avatar
Super Moderator
Re: Voltage Problems!
Well if water is affecting it there must be a leak somewhere. Try to find that first; you should be able to find the problem with it.
Old May 25, 2015
Well that ain't right. The charging system warning light should come on at that time too.
Is the splash shield missing, the one in the wheelwell that helps keep water off of the belts?
Old May 25, 2015
MiniMi's Avatar
Yeah the water issue is weird and a search led me no ware on that issue, all tests lead to bad alty. 200$ ffs lol
the 4 pin plug on the alty has bttery power, and 4.5v i assume is from eld..
and ya the dash lights are weird. Cars in amazing shape but it spent 2 years at the collage as a project car.., so god knows what they did to it
Old May 25, 2015
MiniMi's Avatar
And ya no splash gaurds
Old May 25, 2015
Find the white/blue wire at the alternator plug.
Turn the key on (do not start the engine) and ground that wire, the charge warning light should come on.
If the splash panel is missing, water getting on the belt can allow it to slip and charging ability can be greatly reduced because of this.
I can't say this is your problem, but it's a possibility.
HTH
Old May 25, 2015
MiniMi's Avatar
HTH
Okay i will try that, and belts are not slipping, the water causes a spike (to much voltage) and then a drop.
Old May 27, 2015
MiniMi's Avatar
changed the alty. my battery light works now, got full voltage and my idle is perfect (never was)
cant wait to see what the rain will do now
CarStuff
Dec 6, 2020 12:52 PM
tmc66
Jun 9, 2015 04:07 PM
Black91civic
Jun 6, 2015 08:15 AM
tmort
May 11, 2015 07:13 PM
tkcne
Apr 18, 2015 02:33 AM
