91 brakes power all electrical
Old Oct 10, 2013
george0217's Avatar
george0217 is an unknown quantity at this point
1991 cx, and first my guage cluster stoped lighting and only lighting when the brakes are pressed. then my temperature *****. then my stereo, ad now my rear drl only workwhen my brakes are pressed. this all happened one after another in the span of a week. does anyone even have the slightest clue as to what it could be?
Old Oct 11, 2013
anvilhead's Avatar
anvilhead is an unknown quantity at this point
Re: 91 brakes power all electrical
Ive been trying to help him with this problem, and the only thing I can think of is a short to power. Its been getting progressively worse over the last couple weeks. It started with the loss of dash lights, then radio power, and now is even affecting the exterior lights.
The confusing part is that everything goes back to normal when the brakes are depressed. As soon as the brake pedal is pressed all of the lights illuminate.
Could this be caused by an electrical component of the brake system?
If so, can this be bypassed to test this theory?
Any help would be really appreciated. Thank you
Old Oct 11, 2013
How many and which lights are "all"?
Have you observed all of the exterior lights, do they all function? By all, I mean every last one. Too many people can look at a set of brake lights and say "YUP YOU GOT EM" when there is 3 on the left and 1 on the right and none in the center.... Not kidding one bit.
Do they all come on at full/proper brightness, or are they still dimmer than they would normally be?
If they come on bright, This part alone sounds like what can happen when an 1156 bulb gets stuck in an 1157 socket. This bridges the brake power to the park light power within whichever socket holds the incorrect bulb.
If they come on dim, then I might be testing for ground issues.
The loss of the other lights......Fuses first....I would start with a wiring diagram and a test light or voltmeter.
I'd be checking.....#1 is to figure out what is missing...It's gotta be missing either powers or grounds from the lights that don't work. It won't be both most of the time.
I'd probably do any other testing at the headlight switch connector since most of the light wiring can be accessed and tested at that point pretty easy. Powers, I can use jumpers to manually turn on lights at that connector, etc.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
h4ldol
Jun 3, 2015 03:26 PM
trellex
May 24, 2015 04:39 PM
anddrrey
May 11, 2015 02:30 PM
bsmiley
Apr 27, 2015 01:27 PM
