92 lx 4-dr Driver Side Door Issue
Old Mar 3, 2011
nunzio42's Avatar
nunzio42 is an unknown quantity at this point
There is an issue with the wiring harness on the driver side door. The clip for the harness (between the frt fender and driver doors) is broke. To get the power windows to work you have to wiggle the rubber covering over the harness till it connects, roll the window down, and then close the door.
How hard is this to replace? Can I buy the clip or do I need to replace the entire harness?
Any help is appreciated.
Old Mar 24, 2011
nunzio42's Avatar
Re: 92 lx 4-dr Driver Side Door Issue
Anyone?
Old Mar 24, 2011
lazlong's Avatar
Does it look like #41? http://www.hondapartscheap.com/south...t=0&quantity=0
Or if your not sure just go pull one from: http://www.picknpull.com/default.aspx They'll only charge ya a dollar or two.
Old Mar 28, 2011
nunzio42's Avatar
Ill have to check it out, I think so.....thanks for the help....
Nalmonte
Exterior
Jan 24, 2020 04:55 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
intensity
May 12, 2015 10:43 PM
ej8
Apr 13, 2015 06:36 PM
Macko
Exterior
Nov 19, 2001 10:34 PM
