94 Civic Tail Light Problem
Old Dec 27, 2010
gotvtec86's Avatar
gotvtec86 is an unknown quantity at this point
Hey, I have a 94 Civic Si, and when i turn the head lights on, sometimes i ahve to flick the switch a couple times for the tail lights to come on. And tonight I noticed that they were flickering on and off occaisonally while drive. I could tell cuz the dash clock would brighten, then go dim again. I never thought to look if they flickered when I hit a bump. Any input would be appreciated
Old Dec 27, 2010
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Re: 94 Civic Tail Light Problem
You probably have a loose ground somewhere.
Old Dec 27, 2010
lazlong's Avatar
Originally Posted by gotvtec86
...sometimes i ahve to flick the switch a couple times for the tail lights to come on...
Look for a loose connection at the Multifunction Switch. If no loose connections you have a bad Multifunction Switch. Or it's a bad ground, like stated above.
Old Dec 28, 2010
gotvtec86's Avatar
Thanks guys, I'll check it out
CarStuff
Dec 6, 2020 12:52 PM
tylerginevan
Apr 27, 2015 12:29 PM
dooner24
Apr 14, 2015 07:51 PM
shaejb15
Apr 12, 2015 11:38 AM
reLaXedinca
Nov 2, 2001 06:44 PM
