Help please Deck problem
Old Jun 23, 2010
FourBanger95's Avatar
FourBanger95 is an unknown quantity at this point
I have a 95 civic hatchback so for you to get the deck out you have to remove the center column directly underneath it. (i was connecting my necessary cables for my amp). As i was doing this it started to rain so i didn't place the column back. I believe as i was driving to work with that hanging there it must have pulled on something and disconnected some wires and now my deck will not turn on. From what i saw all that was connected to the column was a cigarette lighter. Can someone please point me in the right direction to try to solve this problem. thanks. Ps fuses are all good and for now my amp is disconnected from my battery.
Old Jun 23, 2010
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
Re: Help please Deck problem
Get a circut tester and test the power wires to the radio and the lighter. if no power to those then trace your steps back to the problem. Good luck.
mohawkboom
67
Aug 25, 2015 12:28 AM
KronikScott
Jun 9, 2015 08:00 PM
Mokushi
Nov 1, 2001 02:40 PM
