1993 No Sound From Speakers
Old Feb 14, 2009
Hyperchunk's Avatar
Hyperchunk is an unknown quantity at this point
Unhappy 1993 No Sound From Speakers
I bought new rear speakers today and was installing them. I took the factorys out and then put in one of the rears, turned the battery on, and everything was great. I put the other speaker on, then turned the car on again. The sound was great for about 4 seconds and then all the speakers shut off, even in the front. Anyone know what could cause this? I've checked every fuse and they're all fine. I don't know where to go from here. Thanks
Old Apr 2, 2009
mrplow123456's Avatar
mrplow123456 will become famous soon enoughmrplow123456 will become famous soon enough
Re: 1993 No Sound From Speakers
Is it a factory headunit and factory replacement speakers? The new speakers could have been trying to pull more current then the headunit could produce and fried it. Everything may still work but you could end up with no sound. Also, it sounds silly but the wires could have been placed on the speakers backwards but unsure if you would have had the same problems. And make sure that everything isn't lost by replacing the rear speakers with factory to see if things don't get better.
Old Apr 2, 2009
wow very strange, ive had aftermarket speakers on the stock deck no problem, even backwards polarity. did you check all the fuse under the dash?
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
CraigW
Aug 18, 2015 07:06 AM
jpandjf
Aug 3, 2015 05:02 PM
Nalmonte
Jul 22, 2015 09:08 AM
