Questions Wiring 1st amplifier
Old Feb 9, 2009
new95civic's Avatar
new95civic is an unknown quantity at this point
Hi all --
sorry to be such a noob -- but I am stuck. I am installing an amp+subs in the trunk of my son's 95 civic lx --- have everything wired and addressed ( I think ) except for how to physically connect the 4gauge power cable to the battery.
The tiny little OEM battery clamp will probably not handle this big 4gauge wire.
I saw some aftermarket clamps but I don't understand how they are to be used -- am I expected to cut the starter and aux wires off the existing clamp and re-install them in one of these heftier aftermarket clamps? + my new 4 gauge power wire? Or is there an easier way that I am not seeing?
Any help appreciated.
Old Feb 9, 2009
Re: Questions Wiring 1st amplifier
well a ring terminal should fit the stock clamp, otherwise you can swap the whole thing for a new "fleet terminal" which is bigger and beefier.
Old Feb 20, 2009
James7491b3's Avatar
James7491b3 is an unknown quantity at this point
Hi mate how did you get the power cable to the battery into the car. Thanks
Old Feb 20, 2009
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
A few options:
1. Go to Home Depot and pick up a ring terminal for 4 gauge wire, it'll slide right onto the battery post, don't worry about it.
2. Pick up a heavy duty terminal from Street Wires which clamps tot he wire via a hex key screw. This is sooooooo easy, I'm glad I have it for my setup. It's just a bigger ring terminal so it should still go on the battery.
3. Or do what I did which is what you suggested. Pick up a clamp for the battery post that has a lot of different places for wires to clamp into and cut your stock wires to go into there as well. I have my stock wiring, 4 gauge amplifier wiring and 10 gauge computer wiring going into different holes in the clamp. It was $20.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Blazz
Jun 4, 2015 01:04 AM
pincookie1
May 4, 2015 12:22 PM
viper775
Dec 9, 2001 10:52 PM
supercivic01
South
Nov 30, 2001 11:27 AM
