Notices
94 Civic Brake Fading issue
Old Mar 7, 2011
docwill2's Avatar
docwill2 is an unknown quantity at this point
Bought a 94 Civic EX, with approx 170K miles. Great car. Service Rep suggested I replace the Brake Master as it was leaking. Since then, the Brakes have failed suddenly on way home from work (40mile drive in traffic). The Peddle feels soft, looses pressure. Pumping, causes incremental lose in pressure.
First Time it happened, I stomped to avoid a non-blinking lane changer. Pedel to the Floor and the car pulled to the Right???
Third Visit to the shop for this issue, was told the issue was due to Brake Fade caused from over heading Brake pads. Was suggested to install Ceramic pads and change fluid to Dot4. $440 later, No Improvement. Still have Soft, fading brakes. Pucker Factor is increasing.....
Any suggestions as to diagnosis, steps to reach Root Cause? Traffic here in DFW is pretty Fast. I avg 75 which is dangerous as traffic stops just as quickly.
Thanks in advance
Docwill2
Old Mar 7, 2011
lazlong's Avatar
Re: 94 Civic Brake Fading issue
Inspect system thoroughly for leaks. This includes master cylinder, lines, calipers (seals on the piston), and wheel cylinders. Replace the leaking part. If no leaks, bleed the system VERY good (at least 3 0r 4 times). I'm assuming you had the master cylinder replaced but, did they adjust the rod coming out of the booster?
If you want help PM me.
Old Mar 8, 2011
docwill2's Avatar
Thanks lazlong
Cannot say for sure yet what was/wasn't done regarding the brakes. Not a motorhead, just do basic maintenance stuff. I'm going back (3rd time), to have them check out the Master Cylinder. Have read other sites that mentioned similar symptoms. The recommended replacing the Master.
One thing to note, the brakes get worse as I drive. I have a 40mile drive, thru heavy traffic (Fort Worth back to Dallas). By the time I get near home, the Pedel nearly bottoms out.
Doc
Old Mar 8, 2011
lazlong's Avatar
Yes, replace the master if it hasn't been replaced already.
Old Jul 19, 2011
rpena001's Avatar
rpena001 is an unknown quantity at this point
I have the exact same issue. I've bought the MS and I'm going to install new pads but I'm wondering why you meant by the rod coming out of the booster. I've done a ton of pads in the past but this will be the first MS I put in so any advice would be greatly appreciated
thanks,
Robert
Old Jul 20, 2011
turbo_coupe_EJ1's Avatar
turbo_coupe_EJ1
turbo_coupe_EJ1 is an unknown quantity at this point
just be sure to bleed the master cylinder
Old Jul 21, 2011
rpena001's Avatar
ok master cylinder went in no problem, I think I had the work done in under 45 minutes. I placed the ear of the new cylinder in a vice and bled the hell out of the new cylinder, to the point that I was only getting little bubble when I would press the rod.
The problem I am facing now is that the brakes are not releasing. I was driving down the road and could smell the brakes and I would have no power. I'm trying to figure out what would cause the whole brake system to lock up like this. Maybe when I reinstalled the cylinder I didn't install the rod from the booster correctly?
Again any further advice will be greatly appreciated.
Old Dec 13, 2011
rpena001's Avatar
wow that sounds just like what my car was feeling like prior to changing out the master cylinder. Any chance you can change out the cylinder for a new one. New parts have been known to come out defective.
As for the problem I described earlier about the brakes sticking, I ended up taking the car to a mechanic to give the whole system a inspection it turns out that the adjustment lever which attaches to the brake pedal needed to be adjusted, wow imagine that. Plus whoever previously installed pads on the car put the inside pads on the outside and the outside pads on the inside. But new pads cost $50 and I did those myself.
In all honesty if you have some tools and access to the internet you can do 80% of the work that is needed on these civics. paying a mechanic is a last option.
Old Dec 13, 2011
rpena001's Avatar
this was meant to respond to docwill2 below
Old Dec 17, 2011
MrDobin's Avatar
MrDobin is an unknown quantity at this point
How the hell did they get the pads switched?. Thats impressive hahaa
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Xuhme
21
Aug 7, 2023 03:40 PM
McD
Apr 29, 2015 03:50 PM
bsmiley
Apr 27, 2015 01:27 PM
civic_gt
Apr 19, 2015 08:15 AM
