Ej2 d15b7 run,s terrible
My ej2 d15b7 loses all power and stutters really bad if u push the throttle more then 10%. This is worse when the engine is at operating temperature. I tried checking the engine codes but when i connect the two pins the engine light just stays on. When the pins are not connected there isn't a engine light. I switched out the o2 sensor for a different one. I also cleaned up the connector on the thermostat housing.
Re: Ej2 d15b7 run,s terrible
Read over this thread. https://www.civicforums.com/forums/2...oes-crazy.html
In your case also suspect failing coil and/or igniter. Do tests as shown in videos.
pritz786
Jul 20, 2017 12:02 AM
Thaik
Jan 19, 2013 06:11 PM
undrmyhood
Jun 5, 2011 03:56 PM
