1996 Honda Civic ex won’t start fuel injectors not firing
Old Jun 9, 2019
Randall Charles's Avatar
Randall Charles is an unknown quantity at this point
Hello everyone I have a issue with my 1996 Honda Civic ex which causes the car not to start up I swapped out multiple ECU’s, distributor, main relay, crank sensor, spark plugs , fuel pump works I can hear it priming. So basically the fuel goes all the way to the fuel injectors but the injectors won’t spray unless I run a wire to ground out injector then it will spray I would really appreciate any help cause I’m stuck
Old Jun 9, 2019
GolNat's Avatar
Prelude Owner
Re: 1996 Honda Civic ex won’t start fuel injectors not firing
None of the injectors work?
Maybe the signal is getting lost somewhere? All engine grounds are secure?
mineister
Jan 3, 2015 03:31 PM
civcspool
Mar 29, 2009 02:11 PM
xacalus
Aug 8, 2005 04:12 PM
Michalo187
Nov 30, 2004 11:30 PM
chefjnr
Nov 20, 2002 10:18 PM
