won't shift into 4th gear
Old Jun 5, 2018
ocnwolf99's Avatar
ocnwolf99 is an unknown quantity at this point
I have a 1993 Civic coupe and it will not shift into 4th gear when cold or when you stop and resume driving in a few minutes. It will shift if you rev the motor with your foot on the brake and then proceed to drive. Thinking shift solenoid. Any ideas?
Old Jun 5, 2018
Wankenstein's Avatar
Re: won't shift into 4th gear
If it's an automatic you can try removing and cleaning the shift solenoids and gasket screens with brake cleaner or simple green. Also inspect the shift linkage on the transmission housing.
Other than that do an ATF drain and fill and hope it's not an internal issue: clutch pack, valve bodies.
phantom-civic
Aug 21, 2006 09:24 PM
SLVR01CIVIC
Aug 5, 2005 09:24 PM
S2000man01
Jun 19, 2005 10:26 AM
Civic_RedLine
Mar 4, 2005 10:42 AM
