miss cyl 2 & 4,,
Old May 12, 2016
91LXdriver's Avatar
91LXdriver is an unknown quantity at this point
miss cyl 2 & 4,,
Last friday on way to work it stared skipping, got a ride home and went back sat and checked plugs, #2 was oily, and 4 was weak, Put in new Plugs. and limped it home. Had to order cap and wires,, Now after putting on a new cap, rotor , and wires its still skiping. any ideas what coud be causing this?
Old May 12, 2016
Re: miss cyl 2 & 4,,
Compression test.
Firing order.
Old May 12, 2016
91LXdriver's Avatar
checked firing order its correct,, compression test?
Old May 12, 2016
What are you calling "skipping"?
I picture.....
That term really isn't in my automotive vocabulary. I guess use of that word may be a regional thing?
Yes, compression test if it's a dead hole miss.
Is it intermittent misses? Misses under load?
Got pics of the plugs you pulled out?
Old May 12, 2016
91LXdriver's Avatar
cyl 2 was wet with oil not foring, 4 was weak spark, was firing just as hot as it should.
Old May 12, 2016
I'm not seeing any pics here.....
Old May 15, 2016
91LXdriver's Avatar
heres pics of clyinder 2 old that was misfiring and new plug that was misfiring,, and cylinder 4 old plug that was weak,,
Old May 15, 2016
Can you get any closer to the important part?
Old May 16, 2016
91LXdriver's Avatar
Mine look like 3rd and 4th pics. 2nd cylinder is like oil fouled, and 4th is like cross of 1 and 3,
Old May 16, 2016
Compression test?
Old May 16, 2016
91LXdriver's Avatar
not yet, gotta find a tester
Old May 20, 2016
91LXdriver's Avatar
Found a tester, now need to know what the compression should be,, whats good and whats not,, my chiltons doesn't have a chart.
Old May 20, 2016
Figure out how to do the test correctly then post your results.
NVM. Here
Engine is all warmed up to operating temperature
Strong battery, maybe even keep a charger on it during test (cranking speed must be consistent throughout the test, a weak battery can skew the results)
remove all spark plugs
disable the ignition (unplug distributor harness)
brick the gas pedal to the floor or use your foot if you are cranking with the key (I usually run the starter from the engine compartment when easily accessible so I use a prop to keep the gas pedal to the floor)
install tester, position gauge where you can see it from the drivers seat (if no helper is available)
crank the engine, keep cranking until the gauge can't climb any higher, plus another few hits just to make sure it's really maxed out the gauge (count hits in your head)
Write down the test result
repeat for each cylinder
Old May 21, 2016
91LXdriver's Avatar
Got My compreesion test done: cyl 1- 175, cyl 2- 0, cyl 3- 180, cyl 4- 175. Not too good, didnt bother to do wet test after 2 came up 0. so whats the prognosis? could it be a carboned up valve or more peobably blown ring?
Old May 21, 2016
2 is a dead hole
Next I would verify the valve clearance is correct, because tight valves (lack of proper clearance or lash) not only can cause low compression, it can cause valves to burn.
Then research 'cylinder leakage' test or 'cylinder leakdown' test. Pressurize the bad cylinder so you can determine where the leakage is and narrow the cause down to a pinpoint.
Christinep928
May 29, 2016 11:26 PM
91LXdriver
May 12, 2016 09:46 PM
Felesca
May 4, 2016 01:11 PM
BBryan
May 2, 2016 08:20 AM
