Please Help Me!!! 93 Civic Starting Problems
Old Feb 4, 2016
erstinsb's Avatar
erstinsb is an unknown quantity at this point
I have a 93 civic dx 1.5 5 speed that has been acting up for a few months now after a year of running perfectly. First thing to go wrong was my dizzy. I replaced that and no more problems. A couple months ago my car started dying at stops randomly. I noticed my car acting up and not wanting to start randomly before this happened. I found out my valve cover gasket was blown and i had oil on my spark plugs. After fixing that problem my alternator went out on me. Put in a new alternator and all seemed fine at first. Now sometimes when the vehicle is stopped it will want to die if i push on the gas quickly. It is also having a hard time starting but once it starts its fine. When i try to start it the car turns over and will sometimes start for a second then die and not start again for a few tries. I am going insane trying to figure this out. I checked for vacuum leaks and did not find any. Both the spark and fuel are good so??? maybe a timing issue? When I replaced the dizzy it was running a little ruff so i took it to a local mechanic and he said he could not fully retard the timing and i would need to have it redone next year. He said it was barley off and should be fine. Any advice would be appreciated. Thanks for your time,
Austin
xorex83
Sep 8, 2015 08:07 PM
2005seTO
Aug 30, 2015 10:32 PM
SpdRcrChk
Nov 15, 2001 11:33 AM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
