The tanks half full !!
Old Dec 9, 2015
Lisa Renee's Avatar
Lisa Renee is an unknown quantity at this point
Re: Who has the most miles on their 7th Gen Civic?
As of today my 2003 honda civic ex 12/9/15 my mileage is a whopping 469,752 and running awesome except for needing to.pass smog diagnostic shows egr valve insufficient air flow and EDL ? Issue
Old Dec 9, 2015
Lisa Renee's Avatar
2003 manual honda civic ex great on gas as long as I make sure it stays in half tank or above ?? If it gets below it start to pull like its ready to run out of gas ??
Old Dec 9, 2015
Lisa Renee's Avatar
Re: 97 dx d19y7 Electrical Load Sensor replacement help...
I haveva 2003 civic ex and im.able to simply replace the part instead of whole fuse box not sure what year that changed but hope its as simple for you . From online directions I was anle to fo.it myself.and saved 100.00 shop wanted !!
Old Dec 9, 2015
Re: The tanks half full !!
Posts copied to one thread.
All right, apparently you figured out your ELD code already?
The EGR code, is it P0401? The passages clog up, you have to remove the intake manifold and EGR distribution plate (it also holds the 4 fuel injectors) in order to clean out all the carbon buildup from the EGR passages.
For the half tank issue, I'd suspect the "sock" or strainer on the bottom of the pump module has clogged. It's not shown in my Honda parts catalog, but is listed on parts store sites.
amrhamed
Aug 7, 2015 11:39 AM
frisbeeguy2
Jul 30, 2015 03:00 PM
Tommy Cohen
Jul 22, 2015 07:54 PM
qlitten
Jul 21, 2015 03:12 PM
