A/C intermittent
Old Jul 24, 2015
mcollins's Avatar
mcollins is an unknown quantity at this point
A/C intermittent
My 95 civic will blow cold air for a few minutes then blows warm ( ambient temperature ). A couple of shops have said it's the compressor, a couple have said its a short somewhere. Any suggestions would be appreciated.
Old Jul 24, 2015
Re: A/C intermittent
When it quits cooling:
See if the compressor clutch is no longer engaged and spinning
See if it has power to the clutch coil
See if the coil has gone open circuit or if it still has proper resistance value
If the above are all ok then:
Apply power to the coil and see if the clutch engages.....If no then push it and see if it then clicks into engaged position
See if the plate and pulley have worn so much that the gap is far too large
h4ldol
Apr 24, 2017 08:16 PM
haloway13
Nov 6, 2015 10:43 AM
jtcavey
Sep 30, 2015 02:18 PM
260000milesgoal
Sep 25, 2015 07:41 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
