1992 Honda civic dx brake fluid leak
Old Jul 5, 2015
Causemo's Avatar
1992 Honda Civic DX
Causemo is an unknown quantity at this point
Hello all, I recently posted a thread about my brakes. They push all the way to the floor. Well today I was pressing the brake pedal over and over and having a friend observe my back right tire as that is where the leak us coming from. Further observation showed a pipe that connects to the wheel is leaking. I recently hit a squirrel and it messed up my exhaust and this pipe in guessing. Does anyone know what this pipe is called? I need to get a new one.
I have circled the pipe that is leaking in yellow. The tire is to the right of the picture. The pipe is connecting to the tire.
Old Jul 5, 2015
Re: 1992 Honda civic dx brake fluid leak
1992 Honda civic dx
Need to know more to pick it out in a catalog. Sedan? Hatchback? Trans? Location?
That's a brake line. You have to be able to describe it good enough so the parts pimp can pick out the correct one from a blurry picture on a car that might not even match what you really have....tell them the location and what all it connects to,
or you can remove the bad line, measure the length and go to a parts store and pick a straight line that's closest and bend it yourself to fit. (MUCH cheaper but may be more work)
Majestics site says it 'may have been discontinued' (sedan) so you 'may need to figure out how to fabricate' a new line to fit.
4 door car; Item #10, assuming you meant passenger side as right
http://www.hondaautomotiveparts.com/...y5=BRAKE+LINES
3 door car, item #12 may still be available
http://www.hondaautomotiveparts.com/...+LINES+%281%29
Also, if this one line rusted out you may well have many more under the car ready to blow out at any time. Brake lines tend to blow out at the worst possible times, when you needed it the most.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
mattdoc
Mar 14, 2017 12:10 PM
LionSpratt
Jan 29, 2017 11:07 PM
bsmiley
Apr 27, 2015 01:27 PM
jessicakaybby
Apr 20, 2015 12:11 PM
