wheel lock
Old Mar 30, 2015
Focus702's Avatar
Focus702 is an unknown quantity at this point
wheel lock
I was driving the other day and hit a small bump and my rear left wheel locked. Now every time I hit a bump the wheel locks but returns to normal after a second. It's a 95 civic ex with coilovers, I need to know what it is I was thinking the struts but I'm not sure.
Old Mar 30, 2015
Re: wheel lock
A strut should not cause tire to lock up unless the tire somehow makes contact with it or other suspension or body.....and there probably would be black rub marks if it did..but I can't see what's happening there.
I'd probably think about brakes causing lock up.
Old Apr 1, 2015
Focus702's Avatar
Re: wheel lock
I inspected the hub area, I wouldn't even be able to tell if there were tire marks because the car is completely black under there. I took the brake apart and it's fine. There is a knock when I push down on that side even if I push lightly. It's the kinda noise you get from popping a dent in the body. There Are Ground control coil overs On Stock SUSPENSION. Just bought the car. It only locks on bumps, and the coil overs are set to the lowest possible setting.
hondadriver95
Jul 13, 2015 09:43 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
ballmich
Jul 9, 2015 11:59 AM
BootyDo
Jul 7, 2015 06:06 AM
Spanky4269
Jul 5, 2015 09:40 PM
