95 civic shift issues
Old Jan 4, 2015
Smbeaver's Avatar
Smbeaver is an unknown quantity at this point
Question 95 civic shift issues
I have a 95 Honda civic with a d15b block and a d16z6 head millage unknown I put a new clutch in it already had a new slave and master I installed a few weeks ago and when the car is running with out the clutch pressed in I can run through all the gears shift with ease it's like the clutch is pressed in but it's not I've tried dropping the tranny and checking the pressure plate the clutch disc throw out bearing pilot bearing all good and installed right I rebleed the system then I removed the slave to see if it was in the hydro system and still no change what am I missing any ideas
I also tried removing the slave cylinder witch should of made it so I coul put it in gear if it was the hydro system and this issue started right after I put the new engine the clutch worked fine until the swap I put a brand new clutch in to eliminate that was told on another forum that it might be the linkage but how would that be if it's all hooked up maybe half shafts I don't know at this point just kind of guessing
Old Jan 4, 2015
Re: 95 civic shift issues
D-
Break that into paragraphs and punctuate properly. One longass sentence is hard on the eyes.....
Does the speedometer give any reading while the engine is running and you are shifting through the gears?
Any grinding noises?
The disc: Did it fit the splines of the input shaft correctly? Wrong disc for the trans you are using?
Old Jan 4, 2015
Smbeaver's Avatar
Question Re: 95 civic shift issues
So I fould out today if the car is off and I put it in gear it will roll
Old Jan 4, 2015
Smbeaver's Avatar
No grinding at all disc was correct the speedo moves so if I put it in second it jumps to show 20mph
Old Jan 4, 2015
If the speedo moves then you probably don't have an axle fully inserted into the trans. See if the inner joints are fully seated in the trans.
......or maybe they are too small for this trans? I wasn't clear on what all got swapped. Either way, if you have a speedometer reading then it's lost the connection between differential gears and the wheels, so that leaves the axles as the likely suspects.
Is an inner CV joint cup spinning but not the rest of the axle? Did you manage to pull an inner joint completely apart within its boot?
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
dragonsblood
Apr 27, 2015 12:28 PM
EC3
Apr 22, 2015 07:55 PM
toastyghosty
37
Jun 10, 2002 01:07 AM
toastyghosty
32
Dec 26, 2001 02:03 AM
