Just quit and won't restart.
Old Jul 28, 2014
DR Cox's Avatar
DR Cox is an unknown quantity at this point
96 civic ex auto -was driving and car just quit and will not restart. No check engine light came on. will crank but no go. when cycle key fuel pump hums. What should I check now ?
Old Jul 28, 2014
Re: Just quit and won't restart.
An engine needs
Compression
Spark
Fuel
In the correct amounts, at the correct times.
What's missing from yours?
Old Aug 3, 2014
nsxvtec's Avatar
nsxvtec will become famous soon enough
If the main (FI) relay is fine ( fuel injectors pressure is good ) them may be spark. Check coil and module in the distributor if you are not getting spark.
Old Aug 4, 2014
BlueEM2's Avatar
Whachya lookin at?
When is the last time you've had the timing belt checked/replaced? You need to check and make sure it's still intact and in position. My bet is it broke or slipped. When it cranks does it sound like a normal crank or not so much?
juror
Suspension DIY
Jul 30, 2019 03:28 AM
CraigW
Aug 18, 2015 07:06 AM
jedi
Aug 3, 2015 04:26 PM
EM_WON
Jul 22, 2015 06:49 PM
suburbanite
Jul 17, 2015 03:05 PM
