Oil In Spark Plug Chamber
Old Jul 23, 2014
Hbac's Avatar
Hbac is an unknown quantity at this point
Hey everyone. New to forum 1st post. 95 CX hatch with D15B8. I have oil on my plugs and wires. I am planning on replacing the upper spark plug seals and the valve cover gasket. Does my particular engine also have lower spark plug seals as well? I understand this is more difficult than simply replacing the upper seals. 8 valve SOHC. Thanks
Old Jul 23, 2014
Re: Oil In Spark Plug Chamber
welcome
Yes, there's a set of 4 O rings between the upper and lower halves of the plug tubes. They harden and crack and let oil leak into the tubes.
Link if I picked the correct car:
http://www.hondaautomotiveparts.com/...R+HEAD+%281%29
You have to pull the rockers/rocker shafts and stands up to replace the seals. The whole assembly can lift up as a large unit, and you can bend the valves if you aren't careful putting it back together.
You need 1 of #17, and 3 of #16 from the pic above.
I've not found them in the aftermarket....
If you want the right parts on the first try, it's dealer only (IF you pick out the right parts. Many parts n00bs have no clue. Look up your own part numbers to make sure it's right.)
And a valve cover gasket set if it isn't already fresh.
HTH
Old Jul 24, 2014
Hbac's Avatar
Thanks for the detailed info. Now I just need to decide if I will tackle this myself.
JohnnyBxo
16
May 9, 2015 05:53 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
MikeyBoy
Jan 26, 2002 06:45 AM
joefufu419
Bolt-on Engine Performance
Jan 7, 2002 09:18 PM
Micks2K1
Dec 10, 2001 07:11 PM
