Smoke from 1995 civic (1.5L)
1995 civic
Was running rough and Blowing smoke - appears to be white. It now runs smooth with new plugs, but still smokes.
No apparent water in oil.
No apparent oil in antifreeze.
Compression check was 190-220 on all 4 cylinders
#2 spark plug looked like the ceramic was broken so I put in new plugs. Now it runs better but still smokes and stinks.
#2 cylinder has highest compression.
#2 cylinder gunked up new plug in less than 15 minutes idle time.
#2 cylinder appears to have oil on top of piston using a flashlight and looking down spark plug hole.
What the hell is it? I thought head gasket, but have good compression and no apparent water in the oil. Valve stem seals?
Re: Smoke from 1995 civic (1.5L)
Pics of the plugs?
Compression test cannot tell you the condition of the oil control rings.
The oil rings could be completely missing and the compression test would still show good.
How fast has it been using oil?
How fast does it use coolant?
How many miles on it?
What sort of air filtration has it had all of its life?
Smoke white, or could it be light blue?
#2 cylinder originally had a plug with broken ceramic. Changed plugs, and the car ran better (but still smoked). New plug in #2 was black and wet and almost completely cover in a matter of 15 minutes.
I have a pic, let me figure out how to load.
Load your pic to an image hosting site,
then find the 'insert image' icon (
) above, put the link there.EDIT: Above the text box in the reply area
Seems like the only way oil will get in is through the rings or the valves, and valves haven't been a big problem area IMO.
How many miles are on the engine?
You might pop the #2 piston out of the block and check out the rings, see if the oil control rings are stuck in the groove. The time to do it is while the head is off.
beneditti
Jan 15, 2016 12:31 PM
WeRkX
Nov 1, 2001 10:33 PM
