need help fast! engine overheating
Old Feb 28, 2013
audi-driver1126's Avatar
audi-driver1126 is an unknown quantity at this point
Hey there, I recently bought a 1994 Honda civic CX with the 1.5 liter D15B7 engine. (16 valve) It has 357,271 km. When i bought it, it ran really good. Ive had it for over a month now and it ran good every day until now.
I was driving down a really rough gravel road with some puddles at a fair speed, water splashed everywhere. By the time i reached dry pavement again, i realized the motor was running very poorly. Here are a list of its symptoms.
- poor engine power when throttle is applied
- heavy hesitation
- temperature gauge fluctuation. Rises up and down near the 3/4 portion of the gauge
-usually starts up easily, sometimes has trouble starting and staying at idle
-engine sputter, revs high but power delivery is weak
I thought maybe it was my thermostat because the lower rad hose was completely cool while the upper rad hose was really hot. I changed the thermostat and it still overheated. I completely removed the thermostat after that and now it stays at normal temperature (1/4) on the gauge. Although it still runs the same. I REALLY need help with this, as i use the car for work
Old Feb 28, 2013
go-part's Avatar
Former Sponsor
go-part is an unknown quantity at this point
Re: need help fast! engine overheating
That would usually be caused by a blockage in the radiator.
- heavy hesitation
The problems you are having are electrical related. I would start off with having your battery and alternator checked out.
Xuhme
21
Aug 7, 2023 03:40 PM
thana
Jun 15, 2020 07:05 PM
blazebrown
18
Jun 2, 2019 12:31 PM
zaboomafoozarg
May 30, 2015 09:21 AM
supercivic01
South
Nov 30, 2001 11:27 AM
