speedo problem "not working"
Old Dec 9, 2012
dukie12's Avatar
dukie12
dukie12 is an unknown quantity at this point
I've my 93 civic dx for about 6 months, and I've always had an issue with the speedo. I have been told its the VSS, so I replaced it, and its still not working. I replaced the cluster, and thats still not working, I was evening going to replace the whole assembly that the VSS is connected to inside the tranny, but it doesn't come out. So, now I'm trying to figure out whats next. Do I need to replace the tranny, or just check the voltage on the back of the cluster?
I NEED HELP!!!!!!
Old Dec 9, 2012
D Murphy's Avatar
D Murphy is an unknown quantity at this point
Re: speedo problem "not working"
Check your fuses in the underdash fusebox, especially fuse 12 and 24.
Old Dec 9, 2012
dukie12's Avatar
dukie12
Theres nothing in slot 12 besides a black think that looks like a fake fuse, and is fine. My car is a dx so there are not alot of fuses under the dash. Is there suppose to be a fuse in the #12 slot?
Old Dec 9, 2012
I show fuse #15 in the dash fusebox runs all the gauges. If any of the gauges work, the fuse and ground are good.
A bad VSS (or its wiring) would leave a trouble code in the ECM.
Most common problem is the speedometer itself. Specifically the circuit board inside the speedo, if you are into trying to fix things like that. (Not the circuit board on the back of the gauge cluster).
Very common problem, and quite likely that a junkyard gauge set was bad too.
Old Dec 10, 2012
dukie12's Avatar
dukie12
The speedomoter I got came straight out of a running civic that I seen working,so it's not that. All the fuses are good. What next? This is a pain.
Old Dec 10, 2012
A good visual inspection of what wiring you can see.
A proper wiring diagram, a volt/ohm meter, and proper troubleshooting.
Does the ECM have any codes?
Old Dec 11, 2012
dukie12's Avatar
dukie12
No codes on the ECM. What settings do I use in the volt/ohm meter for testing those wires?
Old Dec 12, 2012
Errrmmm......
Old Dec 12, 2012
dukie12's Avatar
dukie12
What setting does the ohm meter needs to be on to test the wires
Old Dec 12, 2012
Depends on what you need to test them for.
Voltage, ground, continuity?
The wiring diagram leads my way in the vast majority of electrical related diagnostic work.
Being able to read a diagram can answer most questions. A service manual should answer the rest.
I cannot answer yours as asked.
No help there huh?
Old Dec 16, 2012
dukie12's Avatar
dukie12
Nah, not really. would the haynes manual tell me all that?
Old Jan 9, 2013
SPD*DMN95's Avatar
SPD*DMN95 is an unknown quantity at this point
has it ever worked.. mine was acting funny then quit
Old Jun 10, 2013
iceblue civic's Avatar
iceblue civic is an unknown quantity at this point
I have same issue speedo doesn't work came like that with car along with gas gauge not working properly either and rpm gauge I don't this is right cuz at idle it reads 3000 and no way it idles that high car isn't loud enough for that lol any ideas please help
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
Stylee01
Jan 9, 2002 09:42 AM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
