93 civic ex transmission problem
Old Jul 15, 2012
cs2727's Avatar
cs2727 is an unknown quantity at this point
Question 93 civic ex transmission problem
i have a 93 civic ex that i just got and it grinds when i go from high 2 gear to 3 only. Its not to bad but i was wondering if i could just change the fluid and that could fix the problem. because i will be using this car to get to and from school which is a 40 min drive one way. It has 120,XXX on it and i dont think the tranny fluid has been changed.
I was also wondering if i was to change it if i could use pennziol synchromesh for my tanny fluid?
Thanks cs2727
Old Jul 15, 2012
kellogg6316's Avatar
kellogg6316 is an unknown quantity at this point
Re: 93 civic ex transmission problem
I put that synchromesh in mine but it didn't take away the grind. you might as well put 10w-30 in there. The grind is becouse the synchronizer is worn out. You can just live with it and try to shift at just the right speed to reduce it. You probably won't experience total transmission failure for another 100k.
Old Jul 15, 2012
cs2727's Avatar
okay and you mean like 10w-30 motor oil? I noticed that when i wait from going from 2nd to 3rd it doesnt grind so i guess i just do that it just kinda sucks that i just picked up the car and it already has problems.
mattdoc
Mar 14, 2017 12:10 PM
bsmiley
Apr 27, 2015 01:27 PM
Rinzlor
Apr 24, 2015 10:33 AM
Richkid23
Apr 19, 2015 12:53 PM
Russps
Nov 8, 2001 02:00 AM
