EJ1 won't start after dizzy o-ring replacement. Please help.
Old Jun 29, 2012
RedRkt01's Avatar
RedRkt01 is an unknown quantity at this point
I don't understand why this thing won't start. I fixed some minor leaks today by replacing the valve cover gasket and the distributor o-ring. I also replaced a coolant hose.
When I finished everything I made sure that the single vacuum hose and the only wire connector that I had disconnected were reconnected.
I cleaned up the dizzy cap and reinstalled it, stuffed the wires onto the plugs and then.....nothing. The engine turns but not a single cylinder fired. I do get a faint smell of gasoline from the intake side of the head, but other than that I have no clues as to the problem.
I even checked to see if something was wrong with the coil spring. Nothing there.
Anyone have an idea? Please help if you can.....I just lost my job of seven years and this is the only car I have.
davidpaustin
Apr 30, 2015 11:20 PM
green01civic
Apr 29, 2015 01:36 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
black2k1vtec
Dec 6, 2001 09:49 PM
