92 civic battery light on?
Old May 16, 2012
Shivin1's Avatar
Shivin1 is an unknown quantity at this point
So I have a 92 civic which I recently drove from southern Washington to San Francisco, about a 10 hour drive. The car runs perfectly fine and had no problems on the way there. On the way back however, I was about two hours away from home when I noticed the battery light had come on.
I needed to stop for gas and it started up fine. I took it to a battery and alternator shop and they said the alternator was bad. Its been three days since I've been home, the battery still hasn't died, and the light goes off for a decent amount of time constantly.
Is the alternator actually bad or could it just be a connection problem?
Old May 16, 2012
Stock 99's Avatar
Re: 92 civic battery light on?
Generally if your light is going on and off then the brushes inside the alternator are worn out. They cost about $20 and it's a fairly simple fix.
Old May 16, 2012
04 Honda Civic's Avatar
You could check the wires to the alternator, but the alternator is probably going. Many auto parts stores will test them for you, only catch is you have to remove the alternator.
Old May 16, 2012
Shivin1's Avatar
Ahh that could be a problem as some one has rounded the nuts.. But thank you for your advice I will see what I can do.
CarStuff
Dec 6, 2020 12:52 PM
tylerginevan
Apr 27, 2015 12:29 PM
twtron
Apr 17, 2015 12:09 AM
smmahan
Apr 15, 2015 08:17 PM
SSMatey
Apr 13, 2015 06:09 PM
